Rocker Arm Id?
12 replies to this topic
#1 Zami
Zami
  • 169 posts
Posted 12 November 2018 - 09:30 PM
Is there a way to check to see what lift a rocker arm is?
I have some forged arms but nothing (p/n) to identify if they are 1.3, 1.5 to 1
#2 nicklouse
  • 18,724 posts
Posted 12 November 2018 - 09:31 PM
measure them. or post pics and someone might know them by sight.
#3 Zami
Zami
  • 169 posts
Posted 13 November 2018 - 03:37 AM
Good idea here are the rockersAttached File  IMG_5925.JPG   60.04K   15 downloads
#4 scoop-deluxe
scoop-deluxe
  • 63 posts
Posted 13 November 2018 - 08:17 AM
Is there a casting number on them?
#5 nicklouse
  • 18,724 posts
Posted 13 November 2018 - 08:29 AM
they are "standard" ratio and of the S type.
further reading
https://www.calverst...ral-compendium/
#6 Zami
Zami
  • 169 posts
Posted 14 November 2018 - 02:05 AM
No markings. Thanks for all the responses.
#7 Azbornmini
Azbornmini
  • 93 posts
  • Local Club: Classic Minis of Arizona
Posted 15 November 2018 - 10:51 PM
Regarding rocker arm ID.  I have a set that have 2a534 MS cast into them.  Does anyone have an idea where these are from?
#8 nicklouse
  • 18,724 posts
Posted 16 November 2018 - 12:22 AM
could wll be a copy of the original "Formula Junior" Copper S rockers but an image would be good and i am sure someone who knows better than me will have the info.
#9 carbon
carbon
  • 2,590 posts
Posted 17 November 2018 - 05:48 PM
If you fit offset rocker bushes to this type of rocker you should get about 1.25 ratio
#10 DeadSquare
DeadSquare
  • 3,205 posts
Posted 17 November 2018 - 09:07 PM
Once upon a time, long long ago,  A fellow called Clive Trickey used to contribute to a Mag caller Car and Car Conversions.
It was at the end of March, 50 years ago that I went to a wedding in Winchester.   To replace Goodwood, the Thruxton motorcycle venue had just opened for cars, so on the Monday I went to have a look at it.
Salisbury was not far away, so I decided to look in at Janspeed.  I was nattering with Janos, when the aforementioned Clive came in  "What can I write about next month, Jan" he implored.
On the bench was an SCA head and there was lively chat about the possibility making an Overhead Cam Mini, but Clive questioned the valve lift so I suggested 'rocker ratios'.
Janos nudged me, winked, and proceeded to tell a convincing yarn about angling the valves and welding extension on the rockers.
As Clive walked out, pleased as punch, Janos took the Pirelli calendar off the wall and turned it over to April 1st.
#11 Azbornmini
Azbornmini
  • 93 posts
Posted 28 November 2018 - 02:54 AM
Here is a photo of both types or rocker arms I have.
The one on the left has the number 2A 534 MS, the rocker on the right has no markings, but as posted above they seem to be Cooper S..
Just curious about the one on the left, and where it is from.
Edited by Azbornmini, 28 November 2018 - 02:57 AM.
#12 Spider
  • 15,201 posts
Posted 28 November 2018 - 07:39 AM
It's a Mini Spares copy of the original Forged Cooper S item, only better than the original.
#13 skoughi
skoughi
  • 1,199 posts
  • Local Club: Shetland classic car club
Posted 28 November 2018 - 11:31 AM
I have a set of those "S" rockers from a 1300GT engine I've just obtained, anybody that wants them can have them!
