Minifin Brake Drums
14 replies to this topic
#1 Fastorq
Fastorq
  • 186 posts
Posted 15 November 2018 - 08:17 PM
Hi
Where can I buy Minifins that don’t have the cast in spacer.
Ie original design Minifins
DavidR
#2 Spider
  • 15,230 posts
Posted 15 November 2018 - 08:25 PM
I'm pretty sure no one is currently making them, only the Super Mini Fin varieties, that have the built in spacer.
Unfortunately, the way the spacer is cast on these, they don't lend themselves to being machined either.
So, you're only option will be second hand with all the usual places to look.
#3 DeadSquare
DeadSquare
  • 3,205 posts
Posted 15 November 2018 - 09:08 PM
Have a care, buying old used Minifins.
They have a nasty habit of warping, which is very hard to ascertain before they are fitted.
#4 Bobbins
Bobbins
  • 1,525 posts
Posted 15 November 2018 - 10:46 PM
Is the cast-in spacer the same thickness as the late model standard drum?
#5 mab01uk
mab01uk
  • 12,615 posts
Posted 15 November 2018 - 10:51 PM
Here is an original Minifin ad leaflet:-
http://www.theminifo...hive/?p=2616928
#6 Daz1968
Daz1968
  • 2,058 posts
Posted 15 November 2018 - 10:55 PM
The current ones are same as later spacered drums, however if you do want some standard mini fins they are about as I purchased a pair for rear of my 998 cooper, but unless you are restricted by wheel offset like I am with my 7 inch front discs then you can use the spacered ones with correct offset wheels.
#7 Fastorq
Fastorq
  • 186 posts
Posted 16 November 2018 - 11:04 AM
Love those old ads
I’m going to look at a pair I’ve found advertised locally.
Hope they are originals and not copies with spacers.
#8 Ricewind
Ricewind
  • 61 posts
Posted 08 July 2019 - 03:48 PM
Can Minifins be used on twin leading shoe front brakes as well?
#9 kit352
kit352
  • 244 posts
Posted 08 July 2019 - 04:23 PM
I would love to find a pair without the spacer. Been looking for months and haven't even heard a whisper about some bring available.
#10 Spider
  • 15,230 posts
Posted 08 July 2019 - 07:06 PM
Yes and it was a popular modification 'in the day'. While drum brakes aren't too bad, fitting these drums does improve them.
#11 carbon
carbon
  • 2,590 posts
Posted 08 July 2019 - 09:04 PM
Makes the 2LS brakes less prone to fade, but still a heavy push needed to get it to stop quickly.
In my experience 2LS needs quite a bit more pedal effort than 7.5 discs without servo.
#12 Ricewind
Ricewind
  • 61 posts
Posted 10 July 2019 - 05:05 PM
In the late 70'sI had a 850 Mini van on low profile 10" tyres that had a remote servo and 2LS. I soon took the servo off as it was far too sensitive. Some lightweight kit cars use disc brakes without a servo by using a clutch master cylinder which has a smaller driving piston. I did this trick on my last Berkeley that had metro callipers, I found it more controllable than having a servo, trying to apply a gentle force to servo assisted brakes when you are bricking it in a situation can be difficult. This trick of using a smaller driving piston could be used with drum brakes but with extra leverage comes longer pedal movement, which is less forgiving of poorly adjusted brakes, spongy rubber brake hoses or any unwanted air in the system.
Edited by Ricewind, 10 July 2019 - 05:08 PM.
#13 carbon
carbon
  • 2,590 posts
Posted 10 July 2019 - 05:56 PM
The standard single line 'tin can' brake master cylinder for drum brakes has 0.70 inch bore.
I'm curious, thought the clutch master cylinder was either 0.70 or o.75 inch bore, not smaller than 0.70 inch?
Edited by carbon, 10 July 2019 - 05:57 PM.
#14 Spider
  • 15,230 posts
Posted 10 July 2019 - 07:04 PM
I think the " to servo or not to servo " comes down to the shoe friction material. Certainly some of the harder competition material may be wanting a servo.
#15 Ricewind
Ricewind
  • 61 posts
Posted 11 July 2019 - 08:14 AM
Thinking about it, it may not have been off of a Mini clutch master cylinder as I think the one I used was off of a Jaguar. I seem to remember that the brake pipe had to be adapted to fit the larger thread size on the master cylinder.
I would get the ones with the spacer and, if suitable machine off the unwanted amount of material.
