Dellorto Sidedraft Carb
16 replies to this topic
#1 Fastorq
Fastorq
  • 186 posts
Posted 15 November 2018 - 09:34 PM
Is a 48mm Dellorto DHLA too big ?
#2 nicklouse
  • 18,655 posts
Posted 15 November 2018 - 10:02 PM
for just about any Mini.
but you dont say what you are thinking about putting it on.
#3 DeadSquare
DeadSquare
  • 3,154 posts
Posted 15 November 2018 - 11:40 PM
Yes, and so is a 46 IDA Weber.
#4 nicklouse
  • 18,655 posts
Posted 16 November 2018 - 02:50 AM
interesting comment.
#5 Retroman
Retroman
  • 967 posts
  • Local Club: CDMC
Posted 16 November 2018 - 10:34 AM
What makes you say that ?
The price and hole in the bonnet are big
The carb is a fantastic instrument, which works extremely well, and I will run mine on the old tweeked 970 +060 S next time.
and it can be used on any other A series above about 90hp to great effect
#6 Fastorq
Fastorq
  • 186 posts
Posted 16 November 2018 - 11:28 AM
Hi
All the Dellorto duals whether downdraft or sidedraft or even trijets are the same physical size .. just the throat size that differs 36 / 40 / 45 / 48 ... and I’m told they made a 52 but never seen one of those in the flesh.
46Weber downdraft IDAs are very rare beasts .. AFAIK they were fitted mainly to Ferraris
48Weber IDAs more common in fact still made today in Spain with new tooling.
Unfortunately the Spanish carbs are considered inferior to the Italian Bologna made ones although I think the Spanish ones have a better progression circuit which is more suitable for road use (Italian ones were designed for racing and only had 3 progression holes which meant they couldn’t idle very well and worked best at high RPM)
IDAs are Huge !!!
My question was more about throat size as opposed to physical dims.
Smallest I’ve ever choked a pair of 48 carbs back to was 37mm which “kind of worked” on a 1600 VW beetle
#7 Retroman
Retroman
  • 967 posts
  • Local Club: CDMC
Posted 16 November 2018 - 12:37 PM
The Manta 400 had twin 50 Dcoe's
What you considering the DHLA 48 to go on ?
#8 Fastorq
Fastorq
  • 186 posts
Posted 16 November 2018 - 02:54 PM
Used to re- furb carbs and turbochargers for the performance VW scene .. mostly twin dual 40mm Weber idf ’s and Dellorto Drlas from Alfasuds
more recently the tuning trend in a/c VWs turned to draw thru turbocharging so carbs of choice were modified sidedrafts with improved seals as D/T systems had raw fuel sloshing around inside both carb and Turbo .. lol.
I don’t do that now but kept a few pairs of Italian IDAs and some DHLAs
Am trying to re live my past by building a fast mini .. kinda favouring the original look of twin 1 1/4 su s and have bought a set of scrappers and re built them (for £10 lol) but that limits the level of tune.
Thinking about other options.
Havnt sourced a motor yet.
Edited by Fastorq, 03 December 2018 - 10:25 AM.
#9 Retroman
Retroman
  • 967 posts
  • Local Club: CDMC
Posted 16 November 2018 - 08:46 PM
Sell the twin 1 1/4s and put the money into a good head
Twin HS2 are only of real use on an original Cooper or S
In standard form they only flow 111 cfm which is chronic 1950's tec
Minus the spindle area they are only 1088mm sq compared to an HIF 44 which is 1168mm sq
Build a 1330 with a good head and cam and make use of the IDA some would kill for one
#10 Fastorq
Fastorq
  • 186 posts
Posted 16 November 2018 - 11:11 PM
Few Re builds
Attached File  enhanceW41AR7EO.jpg   74.83K   2 downloads
#11 nicklouse
  • 18,655 posts
Posted 17 November 2018 - 02:24 AM
mmmmmm
will have a look at the choke sizes later as i have no idea off the top of my head.
#12 nicklouse
  • 18,655 posts
Posted 17 November 2018 - 02:26 AM
yep found an improvement over the DCOE 45 on a Maniflow 7"
#13 DeadSquare
DeadSquare
  • 3,154 posts
Posted 17 November 2018 - 09:49 AM
I plugged the inlet ports of an S head, and funneled the IDA from the top of the rocker cover, down between the rockers on a 1,000cc.
It looked great, sticking out through the bonnet, and with a 648 on the track, it went well.
As a road car with a 544, there wasn't enough gas speed until it came on the cam, and with a 731, it rather spoiled the point of it all.
#14 Fastorq
Fastorq
  • 186 posts
Posted 17 November 2018 - 06:18 PM
[quote name="DeadSquare"
As a road car with a 544, there wasn't enough gas speed until it came on the cam, and with a 731, it rather spoiled the point of it all.[/quote]
Don’t know anything about mini cams (yet) but tlhat’s about what I would have expected using an IDA on a mini engine..
#15 nicklouse
  • 18,655 posts
Posted 17 November 2018 - 06:36 PM
some videos of a 1380 hill climb build with 48 IDA
https://youtu.be/kJ0IY8yf0Z8
https://youtu.be/dqfQ0C65SJs
