Starter Issue With The Cold Weather
18 replies to this topic
#1 Kubbar
Kubbar
  • Just Joined
  • 82 posts
Posted 17 November 2018 - 07:08 AM
Hi
I have issue with start the car in the first time.. I have to start four times then car start is this normal or something wrong in the idle valve? The temperature was 17 c i have attached the video please give me advice what shall i do?
Not: when I'm trying to start the car i never push the pedal, if i push it will start
https://youtu.be/7ssZMLvX4xY
Edited by Kubbar, 17 November 2018 - 10:17 AM.
#2 dyshipfakta
dyshipfakta
  • 1,696 posts
Posted 17 November 2018 - 09:27 AM
Give it chance hold on the starter for a little longer first time around. Along as it’s not excessive I’m sure it’s fine.
#3 cal844
cal844
  • 9,626 posts
  • Local Club: TFMOC
Posted 17 November 2018 - 09:55 AM
Can take up to a minute to stay especially with hardly any choke. I now use full throttle when starting the mini
#4 Kubbar
Kubbar
  • Just Joined
  • 82 posts
Posted 17 November 2018 - 10:20 AM
Hi
It should start better once could i do t want to use pedal and my friend tell me the rpm at the first time should be more than 1000
#5 Kubbar
Kubbar
  • Just Joined
  • 82 posts
Posted 17 November 2018 - 10:22 AM
I adjust the throttle and idle air valve to many time now comes better than tge past but means tge rpm should comes high at the first
#6 cal844
cal844
  • 9,626 posts
  • Local Club: TFMOC
Posted 17 November 2018 - 10:54 AM
What you want to do is try using full throttle, as the engine starts to run on the fuel lift off the throttle, I usually let the engine revs reach 1500 under full throttle then snap off the throttle and allow engine to idle at 1000.
With practice it is easy to get the choke set correctly so the car starts and settled at 1000 rpm
#7 Wiggy
Wiggy
  • 1,036 posts
Posted 17 November 2018 - 11:17 AM
It's an MPi, and not necessary to use the throttle.
It seems to be acting normally. About 1100rpm idle on a cold start.
I'm not sure what the problem is?
#8 cal844
cal844
  • 9,626 posts
  • Local Club: TFMOC
Posted 17 November 2018 - 11:58 AM
Ah, my bad! I couldn't view the video ? however the idle speed does sound ok, it should then come down to approx 900 as it warms up
#9 dyshipfakta
dyshipfakta
  • 1,696 posts
Posted 17 November 2018 - 12:21 PM
Hi
Turn the key and hold until the car starts if you release the key before it starts you are causing any idle issues by leaving unburnt fuel. It can take 2-3 seconds sometimes particularly when cold.
#10 Kubbar
Kubbar
  • Just Joined
  • 82 posts
Posted 17 November 2018 - 02:09 PM
Yes but why is not start at tge first time i changed the sparks also, i think the idle valve not working wellor need to adjust
#11 Wiggy
Wiggy
  • 1,036 posts
Posted 17 November 2018 - 03:58 PM
And what happens if you hold the key in the start position?
#12 Kubbar
Kubbar
  • Just Joined
  • 82 posts
Posted 17 November 2018 - 08:19 PM
I put the video link u can see
#13 Wiggy
Wiggy
  • 1,036 posts
Posted 17 November 2018 - 09:05 PM
I'm confused. In the video it appears that the engine turns over briefly but doesn't catch. As if the key is not being held in the start position for long enough.
Just because it doesn't start on the first turn of the engine doesn't mean there's anything wrong.
#14 Kubbar
Kubbar
  • Just Joined
  • 82 posts
Posted 18 November 2018 - 12:18 AM
Hi
My friend car start in one click no need to turn over along and one more things for first start and engine is cold what should be RPM No at tge first until going hot to 900 rpm?
#15 Wiggy
Wiggy
  • 1,036 posts
Posted 18 November 2018 - 12:31 AM
Does your friend have a Mini MPi?
About 1100rpm on a cold start. Then about 800 - 900rpm when warm. Approximately.
A slightly weak battery or past their best spark plugs or HT leads could possibly make her turn over a bit more before starting.
But I don't think you actually have a problem as such.
