Classic Mini Vacuum Adapter
12 replies to this topic
#1 Ol timer
Ol timer
  • 329 posts
Posted 19 November 2018 - 03:16 PM
Maybe a stupid question but when fitting the vacuum adaptor to a 72 mini manifold do I replace the standard carb spacer with the adaptor or is it added as an additional plate, if you know what I mean?
#2 nicklouse
  • 18,724 posts
Posted 19 November 2018 - 03:22 PM
I would have drilled the existing one if it was alloy.
but to answer your question with another what carb are you fitting?
#3 Ol timer
Ol timer
  • 329 posts
Posted 19 November 2018 - 06:28 PM
Has a Hs4 already.. Just want to add a vacuum gauge
#4 Bat
Bat
  • 903 posts
Posted 19 November 2018 - 07:19 PM
Hi,
I'd fit it as an addition if the manifold studs are long enough otherwise as a replacement for the current one.
Cheers  :proud:
#5 Swift_General
Swift_General
  • 871 posts
Posted 19 November 2018 - 09:17 PM
Hi,
Cheers :proud:
You may run into clearance problems with the jet being moved further back, particularly in a '72 as the crossmember depression is less pronounced, and I'm not sure what having 2 spacers would achieve. You may be able to drill and fit a suitable take off to the existing spacer?
#6 nicklouse
  • 18,724 posts
Posted 20 November 2018 - 12:10 AM
Hi,
Cheers :proud:
the problem is many of these things are only thin meaning that you cant use them on their own as linkage parts of the carb can catch on some manifolds and as you say extending the spacer stack can lead to carb clearance issues. why cant they be made standard thickness.
#7 timmy850
timmy850
  • 3,397 posts
  • Local Club: MITG
Posted 20 November 2018 - 12:46 AM
I just used the vacuum adapter plate. It worked fine without the standard spacer
#8 Bat
Bat
  • 903 posts
Posted 20 November 2018 - 09:10 AM
Hi,
Cheers :proud:
It would certainly make it a lot easier!
#9 Ol timer
Ol timer
  • 329 posts
Posted 23 November 2018 - 06:44 PM
I picked up the vacuum spacer from mini spares recently but I was wondering.. I have the minispares inlet manifold that takes a 5/8 UNF blank plug. Is it possible to run a vacuum line in there Via some sort of adaptor? If so where can I pick one up?
#10 Bat
Bat
  • 903 posts
Posted 23 November 2018 - 07:11 PM
Hi,
Yes you could do it that way.
I can't find an adaptor, but you could drill and tap the blanking plug for a 1/8 hose barb...
Cheers  :proud:
#11 mab01uk
mab01uk
  • 12,571 posts
Posted 23 November 2018 - 07:33 PM
This is the one for a servo vacuum pipe but too big for a gauge pipe....
SERVO OUTLET ADAPTOR FOR C-AHT770 MANIFOLD
http://minispares.co.../12H1405MS.aspx
Edited by mab01uk, 23 November 2018 - 07:33 PM.
#12 Bat
Bat
  • 903 posts
Posted 23 November 2018 - 09:27 PM
Hi,
In fact if you can find what the thread is you could use the one out of that plastic spacer you bought...
Cheers  :proud:
#13 Ol timer
Ol timer
  • 329 posts
Posted 23 November 2018 - 10:18 PM
Good thinking. Bat..
