1380 A+ Short Engine - Sold
18 replies to this topic
#1 GraemeC
GraemeC
  • 7,440 posts
Posted 24 November 2018 - 05:26 PM
Photos here: https://imgur.com/a/Mi8xqKC
73.5mm bore A+ block with CMS and decent high tensile bolts
MiniSpares C-STR312 ‘Mega’ 73.5mm pistons which use Omega rings
The bores show no discernible signs of wear and there is no lip.
Very nicely worked MSPD crank & rods - excellent condition crank tail. Rod bolts are ARP.
Big ends are at STD. The one big end cap I took off shows that the bearings here are in really good order and would go again.
Mains bearings are +0.010" - do show some signs of wear and would possibly benefit from the journals having a polish.
SW5 cam (reground on KC256). No followers.
Water pump is MiniSpares Evo type.
Std A+ push rods (stored in number order to they can go back in the correct places).
Std duplex timing gears
I will provide gasket set.
SOLD
Location - LA5 postcode
Edited by GraemeC, 23 December 2018 - 01:04 PM.
#2 Lucas1988
Lucas1988
  • 410 posts
  • Local Club: Frome Mini Club
Posted 24 November 2018 - 06:39 PM
too tempted... let me just go see if can do it though
#3 Jimmy95
Jimmy95
    Starting My Mini Up
  • 4 posts
Posted 24 November 2018 - 10:04 PM
Have you got any photos? :D
#4 GraemeC
GraemeC
  • 7,440 posts
Posted 25 November 2018 - 11:18 AM
I can take some, but they'll just show an engine in a car!
#5 [email protected]
[email protected]
    Starting My Mini Up
  • 2 posts
Posted 26 November 2018 - 07:55 PM
What mileage has the engine done ?
#6 GraemeC
GraemeC
  • 7,440 posts
Posted 26 November 2018 - 08:23 PM
About 8k overall but has been rebuilt at least once in that time - it started life with a Calver cam but the SW5 went in at about 2.5k miles.
Head was refurbed about 500 miles ago.
#7 GraemeC
GraemeC
  • 7,440 posts
Posted 27 November 2018 - 12:37 PM
Having thought about it, I think I'm a bit heavy on the price so I’m dropping it to £1200. I will include in that a MiniSpares AJM100MS gasket kit.
Flywheel assembly now £200 (over £300 new)
Then, apart from carbs/exhaust you'd have the engine in the same spec as me for the 100bhp.
Everything above, now £1500 (original post edited to reflect this)
Edited by GraemeC, 27 November 2018 - 07:17 PM.
#8 [email protected]
[email protected]
    Starting My Mini Up
  • 2 posts
Posted 27 November 2018 - 05:00 PM
Interested, but need to see pictures of engine from several angles
#9 GraemeC
GraemeC
  • 7,440 posts
Posted 27 November 2018 - 06:26 PM
PM me with exactly what you want to see in the pics and I’ll take them on Friday.
#10 [email protected]
[email protected]
    Starting My Mini Up
  • 2 posts
Posted 27 November 2018 - 06:51 PM
Regarding your 12.30 post saying you were reducing the price, it still looks like £1500 for the lot as in your first add
#11 GraemeC
GraemeC
  • 7,440 posts
Posted 27 November 2018 - 07:16 PM
I edited the first post too - it was £1650 for the lot.
#12 [email protected]
[email protected]
    Starting My Mini Up
  • 2 posts
Posted 29 November 2018 - 01:52 PM
Sorry, now sorted
#13 dougie1142
dougie1142
  • 500 posts
  • Local Club: I.M.O.G
Posted 06 December 2018 - 05:27 PM
Any gearbox with it?
#14 GraemeC
GraemeC
  • 7,440 posts
Posted 06 December 2018 - 07:30 PM
There’s no gearbox as part of what’s listed.
I could supply a rod change one as an extra, but it would need to be considered as needing a re-build.
#15 keule_k
keule_k
  • 12 posts
  • Local Club: LE-Minis
Posted 11 December 2018 - 03:25 PM
God, if it wouldn be 1.500km one way that would be so tempting!!! :(
