Are fulcrum pins ( lower arm ) difficult to replace? Have a 1990 Mini 998cc manual 4 speed. I think my bushings are shot on them. Thanks for any ones help or info.
Fulcrum Pins
Posted 25 November 2018 - 02:20 PM
Posted 25 November 2018 - 02:23 PM
not that hard. the inner sleeve can get get stuck. flame can also help at times.
Posted 25 November 2018 - 04:48 PM
They are straight forward enough, just a lot of brute force to get them out. Easier when the frame is off the car, but that.s not always possible.
Heat as nicklouse says, but be careful using a flame. The bushes don,t produce lots of heat or smoke, but care is needed because of the obvious.
The inner sleeve of the bushes seizes on the fulcrum pin 8 times out of 10, that is why they are a pig to get off and out. You could fall lucky and the pin may come out easy, if so, great ! The rubber sort of disintegrates and forms a shape all of its own
This pin itself takes a lot of pounding in its life time if you think about it. I.ll leave you to decide how to progress further with replacing or using the pin again, but personally, I know what I would do. If that pin was to come out at a later date, it will make one hell of a mess.
Posted 26 November 2018 - 02:20 PM
Thank you both for the info :)
