Fuel Pump Assembly Nut Size / Measurements
5 replies to this topic
#1 minivictor
minivictor
    Just On Tickover
  • 9 posts
Posted 30 November 2018 - 02:00 AM
Hey there everyone. I recently converted from a standard fuel tank to the MPI fuel tank, and I am having trouble locating the proper nuts to secure the fuel pump assembly to the tank itself.
I tried using 1/4"-28 NPF nuts which seemed to work but then they started stripping the threads once tightened. With this, I also tried metric with a 6M-1.0 nut, and it was too small. Tried the 7M-1.0 as well, and it was too big.
Does anyone have any info as to what the thread pitch / size for the 6 nuts are? I have ran to different hardware stores and cant seem to find any solution.
Thanks!
Edited by minivictor, 30 November 2018 - 02:00 AM.
#2 Wiggy
Wiggy
  • 1,036 posts
Posted 30 November 2018 - 02:10 AM
I don't know, but have you tried 1/4" unc?
#3 minivictor
minivictor
    Just On Tickover
  • 9 posts
Posted 30 November 2018 - 02:20 AM
^^ Yes sir. I tried 1/4" - 20 UNC but it didnt bother turning when mounted
#4 GraemeC
GraemeC
  • 7,446 posts
Posted 30 November 2018 - 07:56 AM
NPF? Never come across that thread form.
I’d expect them to be UNF
#5 minimat
minimat
  • 690 posts
  • Local Club: anglian mini club
Posted 30 November 2018 - 11:24 AM
Are they not metric, most newer parts added over the years have metric fittings
#6 minivictor
minivictor
    Just On Tickover
  • 9 posts
Posted 01 December 2018 - 08:45 PM
This has been resolved. To confirm, the correct nut size for this applicaiton is M6-1.0. Preferably with a flanged end.
The reason why it seemed like the M6-1.0 originally did not fit was because there was a significant amount of paint on the threads from the manufacturer. With the heavy coat of paint, the nut originally seemed too small when tightened by hand at the hardware store. Once I used a wrench, the paint was properly shaved off.
Edited by minivictor, 01 December 2018 - 08:46 PM.
