Mig Welder Gas ?
17 replies to this topic
#1 leepol83
leepol83
  • 1,744 posts
Posted 02 December 2018 - 05:17 PM
Hi chaps I have a mig 110 en turbo gas/no gas I want to use gas but it only has a small pipe on the rear of the welder, can I use a larger bottle and how do I connect that to the small pipe in the welder ?
Thanks chaps
#2 alex-95
alex-95
    I am THE CLAMP MAKER
  • 6,034 posts
Posted 02 December 2018 - 05:52 PM
Something like this, may be able to get it cheaper https://www.ebay.co....5cAAOSwOyJatOLh
#3 leepol83
leepol83
  • 1,744 posts
Posted 02 December 2018 - 06:12 PM
Brilliant thank you that’s great stuff appreciate it
#4 Magneto
Magneto
  • 889 posts
  • Local Club: KC MINI Club
Posted 02 December 2018 - 08:47 PM
You also need a gas regulator....
#5 leepol83
leepol83
  • 1,744 posts
Posted 02 December 2018 - 08:58 PM
Thanks magneto I’ll get one of those to
Cheers pal
#6 nicklouse
  • 18,663 posts
Posted 02 December 2018 - 09:10 PM
Cheers pal
got a local Bauhaus? they do gas bottles you buy the first and then refill when empty. refills are about 35 Euro. note the bottle fitting for the regulators are different UK to EU and others.
Edited by nicklouse, 02 December 2018 - 11:10 PM.
#7 Avtovaz
Avtovaz
  • 1,263 posts
Posted 02 December 2018 - 11:09 PM
Depending on the gas you want, the regulator fitting is different by the way. If you go for c02, the fitting to the bottle on the gauges is female, and with say boc argashield would be male.
I use c02, bottle is £50 from Boss gasses in Wigan [refunded if you return the bottle], refills are £15, it welds fantastic with my inverter mig. You can weld probably the worst mini start to finish on one bottle. When i had the transformer style mig, I cant quite remember, but i think i just took out the fitting on the outlet port on the gauges, and screwed in a 4mm air fitting. But that was in my case, get your bottle sorted, and gauges, and goto a local hydraulics place, they will sort it out for you for pennies if they charge you at all..
Flux wire is rubbish
Edited by Avtovaz, 02 December 2018 - 11:11 PM.
#8 leepol83
leepol83
  • 1,744 posts
Posted 02 December 2018 - 11:14 PM
Thanks for all the reply’s really appreciate it, what gas is best as I’ve never welded with gas before I always used gasless before
Edited by leepol83, 02 December 2018 - 11:15 PM.
#9 Avtovaz
Avtovaz
  • 1,263 posts
Posted 02 December 2018 - 11:22 PM
I tried welding in a cage in my friends talbot samber with a gasless welder, and went home for my gas welder, i jsut could not get on with it.. My job is welding also by the way!
Co2 mate, it welds so well, easy to get hold of, and refills are cheep. You can practice welding and not have to really worry its costing you too much.
#10 nicklouse
  • 18,663 posts
first find you local supplier that works best for you. if they are always closed when you might need them forget it.
Like i said got a local Bauhaus? they have good Mig gas. got a local Linde? they can also help but only mon - friday.  the number of times i have popped into Bauhaus on a Sat Afternoon/evening as i have just run out...... dont go too big on the bottle unless you have a whole car to do.
#11 nicklouse
  • 18,663 posts
Posted 02 December 2018 - 11:26 PM
what i use and volume.
#12 Magneto
Magneto
  • 889 posts
Posted 03 December 2018 - 03:24 AM
Over here in the states we use "MigMix" which is 75% CO2 and 25% Argon....inexpensive and lasts....as long as you have the regulator set right. 15-17psi is plenty in a closed shop....ie:no wind blowing thru.
#13 r.tec
r.tec
  • 196 posts
  • Local Club: SfG Schoenau
Posted 03 December 2018 - 08:13 AM
..over here, too. It's called CORGON. But it is the other way round: 18% CO2 and 82% Argon.
And one can buy Argon 4.6 for MIG-Welding Aluminium and Stainless Steel.
Edited by r.tec, 03 December 2018 - 08:20 AM.
#14 nicklouse
  • 18,663 posts
Posted 03 December 2018 - 08:29 AM
yep the Tycon 18 is the same mix 18% CO2 and 82% Argon.
#15 leepol83
leepol83
  • 1,744 posts
Posted 03 December 2018 - 09:42 AM
Cheers chaps co2 it is then thanks again really appreciate it
