Does Anyone Make A Blanking Plate For The Bulkhead Hole?
17 replies to this topic
#1 Pullstarter
Pullstarter
  • 36 posts
Posted 04 December 2018 - 12:36 AM
Hey guys,
Does anyone know of any companies (or individuals) that make a blanking plate for the silly, massive hole in the bulkhead behind the carb in early minis? I know the cover/jute mat things are available but would like to have something more substantial and offering a cleaner look if possible?
Simon
#2 Cooperman
  • 23,320 posts
Posted 04 December 2018 - 12:44 AM
You can make your own with a sheet of 1.2 mm thick aluminium.
However, the speedo cable will need to go through the plate, or you can use a longer speedo cable from a BMC1100 and run it into the car near the wiper motor then behind the interior trim with a 90 degree elbow into the back of the speedo.
For motor-sport the bulkhead must be fireproofed, so an aluminium plate is required there. It should be sealed with a flexible sealant.
#3 Pullstarter
Pullstarter
  • 36 posts
Posted 04 December 2018 - 01:47 AM
Cheers. I was thinking about that but the loom and speedo cable (as you say) would need to be dealt with. Was hoping someone made one so I didn't have to lol.
#4 mab01uk
mab01uk
  • 12,501 posts
Posted 04 December 2018 - 07:24 AM
Minis fitted with the 'Clubman style' dash (dials in front of driver) have a black metal blanking plate screwed over the bulkhead hole. This plate includes a large grommet for the wiring loom to pass through and a pressed in indentation to give clearance to the SU Carb. They come up for sale on ebay, sometimes with the wiring loom attached.
Classic Austin Rover Mini Bulkhead Plate
https://www.ebay.co....tm/382618722709
https://www.ebay.co....5.c100008.m2219
However when a central speedo is fitted it is tight for space behind and a hole is needed for speedo cable. The large hole was omitted from very late Minis and also from the rear bulkhead which were originally used when bodyshells were mounted on a rotating spit for some processes like body dipping at the factory. (see BMC you tube videos)
Edited by mab01uk, 04 December 2018 - 07:31 AM.
#5 Chris.Williams
Chris.Williams
  • 679 posts
Posted 04 December 2018 - 08:15 AM
http://www.dsnclassi...sport-no-holes/
#6 Cooperman
  • 23,320 posts
Posted 04 December 2018 - 11:00 AM
It is a good idea to fit a metal plate over the hole in the rear seat panel.
The idea of just a fibre board cover between the passengers and a petrol tank is not ideal.
#7 mab01uk
mab01uk
  • 12,501 posts
Posted 04 December 2018 - 12:40 PM
That DSN type of blanking plate in link is not for the large bulkhead hole behind the central speedo (when fitted).....it only blanks off the heater hose hole/ LH/RH drive master cylinder holes.
Edited by mab01uk, 04 December 2018 - 12:40 PM.
#8 Chris.Williams
Chris.Williams
  • 679 posts
Posted 04 December 2018 - 05:02 PM
Always pays to read throughly haha ? my bad haha
#9 Pullstarter
Pullstarter
  • 36 posts
Posted 04 December 2018 - 08:56 PM
Thank guys! All helpful info :)
#10 leaky
leaky
  • 6,890 posts
Posted 05 December 2018 - 10:43 PM
What you want is one of these!
46482630_10156587071576023_1489104481948
#11 leaky
leaky
  • 6,890 posts
Posted 05 December 2018 - 11:04 PM
I haven't got a link to them but on facebook if you look for the Classic Minis Japan New and Used parts page and look though you will find the pic which the bloke thats selling them.
#12 Pullstarter
Pullstarter
  • 36 posts
Posted 06 December 2018 - 08:20 PM
Awesome! Thank you very much indeed! That guy also appears to be making Gin in his master cylinder reservoir :proud:
#13 nicklouse
  • 18,662 posts
Posted 06 December 2018 - 08:38 PM
http://carbonweezel....mini/index.html
#14 Pullstarter
Pullstarter
  • 36 posts
Posted 06 December 2018 - 08:51 PM
Seems a shame to cut into it for speedo cable and oil pressure lines, it's too pretty.
#15 Mini ManannĂ¡n
Mini ManannĂ¡n
  • 2,859 posts
  • Local Club: man Estate
Posted 07 December 2018 - 10:11 PM
Always pays to read throughly haha my bad haha
you got the wrong hole :-) Happens more and more often as I get older..
