Hello fellow Miniers
My girlfriends mini has had a leak for a while and this last weekend I had some time to try and find it. Rather than try to explain it, I got a picture of it
https://imgur.com/a/hrj4fcH
So the water is coming between the glass and the rubber, and then through some holes in the door frame finding it's way inside the car. I've tried adjusting the glass with the plastic bits on the bottom of the door and that's as close to the rubber as it gets. It's my first time dealing with this kind of leak so I wanted to ask if theres any way of fixing this or should I just buy a whole new weatherstrip? I compared it to the other door and it looks the same, the rubber doesn't seem damaged in any way, so I can't understand what is causing the issue.
Passenger Window Leak
Junket
, Dec 11 2018 09:40 AM
No replies to this topic
