Brake Drum Won't Slide Over New Pads
11 replies to this topic
#1 muller295
muller295
  • 53 posts
Posted 12 December 2018 - 11:36 AM
As mentioned in the title, I have a problem with reinstalling the brake drum after having fitted new pads. When I adjust the pads, I can't get them adjusted enough to fit the brake drum. I was thinking this had to do with the brakes being bled recently with the old pads still on. Is there some smart trick to fix this without having to bleed the brakes again?
Thanks in advance
#2 nicklouse
  • 18,705 posts
Posted 12 December 2018 - 11:37 AM
often it is just not having the pads centered correctly.
front or rear?
#3 DeadSquare
DeadSquare
  • 3,197 posts
Posted 12 December 2018 - 12:06 PM
Tongue-in-cheek:-
Soak the shoes in Duckhams 20/50, the drum should slide over very nicely;   it also stops to them locking up.
#4 muller295
muller295
  • 53 posts
Posted 12 December 2018 - 12:14 PM
front or rear?
Rear, I have discs in front if that matters. 1992 SPI. I tried fiddling with the pads a little but didn't get it to work, although it seems that it's the upper side where the problem is.
#5 muller295
muller295
  • 53 posts
Posted 12 December 2018 - 12:17 PM
Tongue-in-cheek:-
Yeah I usually do that when my brakes are squeaking, works like a charm!
#6 nicklouse
  • 18,705 posts
Posted 12 December 2018 - 12:19 PM
front or rear?
then move them down. if the adjuster is fully adjusted out and wedges are on the flats not corners then you should not have any issues.
#7 whistler
whistler
  • 1,824 posts
Posted 12 December 2018 - 12:55 PM
Tongue-in-cheek:-
Stop it. Castrol R would make an interesting odour. Lol.
#8 MikeRotherham
MikeRotherham
  • 987 posts
Posted 12 December 2018 - 02:37 PM
Are the brake shoes installed with the correct orientation?
Are the return springs fitted correctly?
Are the handbrake levers fitted correctly?
I had a similar problem with mine when fitting existing brake shoes after replacing brake cylinders. Swapping the brake shoes over to the other side and the drums went straight on.
#9 JXC Mini GT
JXC Mini GT
  • 855 posts
Posted 12 December 2018 - 03:14 PM
Is the handbrake cable to tight (been over adjusted to compensate for worn shoes)?
#10 Rorf
Rorf
  • 866 posts
Posted 12 December 2018 - 06:23 PM
Drums with pads - there's your problem; Install some brake shoes, might help :D
#11 russo
russo
  • 191 posts
  • Local Club: Minis In Nelson Inc.
Posted 12 December 2018 - 07:17 PM
Make sure brakes assembled correctly as per manual, if so, then disconnect the handbrake cables and make sure adjusters completely free and out to the stage you can turn them with your fingers.
#12 muller295
muller295
  • 53 posts
Posted 15 December 2018 - 04:49 PM
Finally found the problem! Turned out that the adjuster didn't go all the way because of corrosion, so it seemed like it was fully adjusted when it wasn't. Thanks for your help everyone!
