Due to a leaky seal I had to remove the timing cover and chain etc on my 1293, which I had to remove the cam retaining triangle plate. The below photo is what I found, Slightly excessive. I checked the end float when I was building it and was about 0.15mm (6thou) so within tolerance, I measured this without the oil pump fitted, is this correct? Other than the oil pump not being machined deep enough so therefore "clamped" the cam against the plate or the plate being too soft what else could cause this? I'm hopefully going to test the hardness of the new plate pictured against and original one tomorrow.
