Spot Welder ?
12 replies to this topic
#1 leepol83
leepol83
  • 1,744 posts
Posted 23 December 2018 - 07:43 PM
Hi all will this cut it on a mini ?
Clarke CSW6T spot welder
#2 neal
neal
  • 318 posts
Posted 23 December 2018 - 08:00 PM
Yes, buy yourself a tip dresser you'll need one to keep them in order.
I bought some angled extension arms to get at the tricky areas, you will find the standard 90 degree ones are fine for sill lips, A post etc. but can it can be tricky around certain areas such as around the rear wheel arches.
Edited by neal, 23 December 2018 - 08:07 PM.
#3 leepol83
leepol83
  • 1,744 posts
Posted 23 December 2018 - 08:11 PM
Thanks Neil what’s a top dresser ?
#4 neal
neal
  • 318 posts
Posted 23 December 2018 - 08:17 PM
A tip dresser keeps the tips of the electrodes the correct shape, the tips overtime due to heat will flatten out and more current will be required for a successful weld.
#5 neal
neal
  • 318 posts
Posted 23 December 2018 - 08:24 PM
Look this up on this site mate, it may help.
Advice For Using Clarke Csw6T On A Project?
#6 leepol83
leepol83
  • 1,744 posts
Posted 23 December 2018 - 08:32 PM
Brilliant great tool!
You said about the arms what type do you use for the wheel arches.
Thanks buddy appreciate you’re help
#7 neal
neal
  • 318 posts
Posted 23 December 2018 - 08:42 PM
https://www.clarketo...ot_Welders.html
I bought Clarke Ext. Arm For Spot Welder - 120mm Throat  (Ref: 6030115)
These helped me to spot weld around the rear wheel arches when I replaced the rear quarter panels, the standard arms would allow the electrodes to grip the thin seem. Most external body panels can be done with the standard arms but you will  soon see what I mean.
I would defo buy some extra tips though, I think I bought mine via ebay, just depends on how much spot welding you need to do.
#8 leepol83
leepol83
  • 1,744 posts
Posted 23 December 2018 - 09:25 PM
Brilliant cheers buddy appreciate you’re help ??
#9 stumpy75
stumpy75
  • 291 posts
Posted 24 December 2018 - 02:10 AM
Can that be run from stock 13 amp plug and what about the bigger model the 13
#10 fiestaharry
fiestaharry
  • 295 posts
Posted 24 December 2018 - 11:54 AM
I find these arms the best out of the sets i have
https://www.machinem...amp-120mm-thro/
You would be best running off a 32a industrial socket
#11 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,092 posts
  • Name: Neil
Posted 24 December 2018 - 05:01 PM
I run mine on a 16amp socket with a 16 Amp MCB. No problem with it tripping.
#12 fiestaharry
fiestaharry
  • 295 posts
Posted 24 December 2018 - 05:28 PM
I have ran mine from a 13A socket, if you do go down this route, it will blow fuses alot, i am now running from a 32a socket fed from a good generator and the quality of the weld is alot better
I would also advise getting one with the timer on, i am using a sureweld:
https://www.weldequi...ospot-m230f.htm
#13 neal
neal
  • 318 posts
Posted 24 December 2018 - 06:27 PM
I did this as well, 2.5mm 3 core flex fly lead from the consumer unit on a 16 amp MCB, no problems. You may need a type 2 MCB for nuisance tripping but perfectly fine. If you are not electrically minded or you feel unsafe doing it then contact an electrician to fit and remove it, should take 20 minutes tops.
