Brake Bias Valve
7 replies to this topic
#1 pusb
pusb
  • 1,216 posts
Posted 29 December 2018 - 09:47 AM
Have I reinstalled this the right way around?
I've got pictures of it beforehand, but they aren't close enough to show detail.
#2 Ethel
  • 26,086 posts
Posted 29 December 2018 - 10:42 AM
You have if the one connected pipe is to the rear brakes.
The connection above it is to the master cylinder's bottom outlet if it has a yellow band, also identifiable by the bigger diameter on that outlet compared to the top.
#3 pusb
pusb
  • 1,216 posts
Posted 29 December 2018 - 11:15 AM
Thanks very much.
Also, when using ready made pipe kits, I don't suppose you know how to determine which end of the front to rear pipe is which? I know one is metric and the other is UNF, but other than just trying both to get a feel, is there a way to tell?
#4 Itsaminithing
Itsaminithing
  • 853 posts
  • Local Club: Not One Worth Mentioning
Posted 29 December 2018 - 12:22 PM
The metric thread fittings should have a notches on the head, the UNF fittings don't.
https://www.automec....e-pipe-fittings
.... so it looks like that's the wrong end you've fitted as the AP bias valve uses metric threads.
#5 pusb
pusb
  • 1,216 posts
Posted 29 December 2018 - 12:28 PM
Thats great, thank you.
One of the ends does have those notches on it
#6 Ethel
  • 26,086 posts
Posted 30 December 2018 - 12:00 AM
M10x1 is slightly bigger diameter than 3/8unf which at 24tpi is one turn less in an inch.
#7 Spider
  • 15,154 posts
Posted 30 December 2018 - 02:14 AM
If it screws in by hand in to a wheel nut, then it's 3/8", if it doesn't, then it's M10.
I suggest this as it can be hard to pick at times, if the nut doesn't have the identifying marks on it.
#8 Ethel
  • 26,086 posts
Posted 30 December 2018 - 02:37 PM
Yes, it can be hard to judge with the pipe pushing it out of perfect alignment.
If you've got the space to do it, then putting the threads of a male union against a wheel stud should easily show up if the pitch isn't the same.
