Are Spi/mpi Fuel Tanks The Same?
11 replies to this topic
#1 blackbelt1990
blackbelt1990
  • 2,614 posts
  • Local Club: Minimus Maximus
Posted 30 December 2018 - 12:42 PM
I seem to have misplaced the fuel tank from my SPi, before I start shopping, are all injection ones the same?
#2 hazpalmer14
hazpalmer14
  • 685 posts
  • Local Club: cumbria mini cruisers
Posted 30 December 2018 - 01:10 PM
They are the same in fitment but the mpi pump is different. The mpi flows more I think. I only know this because it is common to fit the mpi for turbo use. You need to keep the fuel pressure 4psi above boost pressure and the spi pump is only good for 10psi of boost I tjink. Can't remember off the top of my head. The pumps can be swapped out for other ones though.
#3 mini13
mini13
  • 3,811 posts
Posted 30 December 2018 - 04:26 PM
The mpi tank is foam filled, and has a lower profile filler spout but interchangeable apart from that, the spi has a pump that internally regulates to approx 1 bar, so as said only good for about 10-12psi boost but you can swap that out. The mpi pump is a generic injection one, so can make 60 psi+ so you need a fuel reg at the engine.
#4 blackbelt1990
blackbelt1990
  • 2,614 posts
Posted 30 December 2018 - 05:55 PM
Cheers all
#5 Steve220
Steve220
  • 5,067 posts
  • Local Club: BMC
Posted 31 December 2018 - 11:35 AM
Foam filled? I've got 2 spare here as well as the one in my car, and they're not..
#6 mini13
mini13
  • 3,811 posts
Posted 31 December 2018 - 11:52 AM
actually I think they just have baffles,
#7 Steve220
Steve220
  • 5,067 posts
  • Local Club: BMC
Posted 31 December 2018 - 03:40 PM
Not that either.
#8 mini13
mini13
  • 3,811 posts
Posted 31 December 2018 - 05:26 PM
Interesting, that'll teach me to check and not just go by the common consensus!
#9 FlyingScot
FlyingScot
  • 2,664 posts
Posted 09 January 2019 - 11:17 PM
Nope it’s the regulator in the SPi throttle body that regulates to 1bar, tank pump in an SPi can do about 3bar
FS
#10 Bobbins
Bobbins
  • 1,512 posts
Posted 29 January 2019 - 03:34 PM
So back to the OP question ... is an MPi tank identical to an SPi tank?
I'm considering swapping the injection on my JDM Cooper over to MPi (from SPi) and running it on an MPi ecu, I'm starting my investigations as to what might be involved.
#11 blackbelt1990
blackbelt1990
  • 2,614 posts
Posted 30 January 2019 - 09:20 AM
No idea! Haha
I managed to get an SPi one cheap in the end, so I didn’t need to check.
#12 FlyingScot
FlyingScot
  • 2,664 posts
Posted 05 February 2019 - 11:41 PM
Change the internal pump to the MPI or aftermarket one (Walbro) that is all you need to do.
FS
