Windscreen Fitting.
11 replies to this topic
#1 DUF2
DUF2
    Formally known as DUFfi
  • 456 posts
  • Local Club: Whickham & DMC
Posted 31 December 2018 - 07:36 PM
I have removed & refitted glass to a number of cars in the past. Each one had a one piece endless rubber surround ie no joint
I have had to remove the front & rear screen to allow the car to be painted and find in both the front and rear screen rubbers there was a joint, ie 2 ends
Whilst cleaning things up I refitted the rubber to the screen having glued the two ends together, the rubber is too loose around the screen.
should the  (now) endless rubber be a snug fit around the glass?
whilst looking at the Mini Spares site, I see they suggest when fitting " REMEMBER YOU MUST FIT THE RUBBER TO THE BODY FIRST. DO NOT USE THE STRING METHOD BECAUSE IT STRETCHES AND TEARS THE RUBBER"  This is a new one to me, in the past all I have done is to fit the (endless) rubber surround to the glass then drop the glass & sealing rubber into the aperture and use a greased cord to pull the rubber edge over the lip.
Any advice would be appreciated
#2 GraemeC
GraemeC
  • 7,439 posts
Posted 31 December 2018 - 07:42 PM
Seal to the metal is the correct way to fit a seal with a locking strip.
Seals without locking strips (ie fixed side windows) can be fitted to the glass first.
#3 nicklouse
  • 18,649 posts
Posted 01 January 2019 - 12:09 AM
Also note the rubbers seem way too big. They are not.
#4 nicklouse
  • 18,649 posts
Posted 01 January 2019 - 12:50 AM
And re the fitting to the body. As the rubber holds assorted trim in place it saves you messing up your headliner.
I have fitted them with the rubber on the screen but it was to a bare shell.
#5 DeadSquare
DeadSquare
  • 3,146 posts
Posted 01 January 2019 - 09:26 AM
Fit the rubber to the shell with the join at the top to stop any water running down the screen getting through the join and fit the locking strip with the join at the bottom to let any water out that might get in.
#6 DUF2
DUF2
  • 456 posts
Posted 01 January 2019 - 10:40 AM
So, if I fit the rubber to the screen aperture first, how do I pull the rubber over the screen? Do I still use a cord?
#7 Wizzalong
Wizzalong
  • 100 posts
Posted 01 January 2019 - 11:35 AM
I'm interested to know too.
#8 GraemeC
GraemeC
  • 7,439 posts
Posted 01 January 2019 - 11:51 AM
Sit the screen into the rubber at the bottom then use a BLUNT tool to ease the rubber over the glass. I use bike tyre levers and glass cleaner as lubricant.
#9 DeadSquare
DeadSquare
  • 3,146 posts
Posted 01 January 2019 - 12:37 PM
Several Magnum ice-cream sticks and fairy liquid.
#10 GraemeC
GraemeC
  • 7,439 posts
Posted 01 January 2019 - 12:59 PM
Ah but now you’ll get the arguements over Fairy liquid containing salt...
#11 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,053 posts
  • Name: Neil
Posted 01 January 2019 - 01:38 PM
Yup you will, use car shampoo instead.
#12 GraemeC
GraemeC
  • 7,439 posts
Posted 01 January 2019 - 01:50 PM
KY jelly (other personal lubricants are available!)
