Windscreen Washer Piping
16 replies to this topic
#1 Rio
Rio
  • 85 posts
Posted 11 January 2019 - 01:08 PM
Having just acquired the Mini, there was only one jet fitted and piping broken. On the basis that I could see some water come out and I could hear the pump working, I bought all new piping for the engine bay area and fitted 2 new jets. Now, when I activate the washers, one dribbles and water leaks from somewhere under the front drivers wing onto the ground. Where does the piping run from back to front as it looks like I'll have to replace a lot more.
Andrew
#2 GraemeC
GraemeC
  • 7,440 posts
Posted 11 January 2019 - 01:19 PM
It goes through the bulkhead, up the A post, along the cant rail and down the C post.
#3 Rio
Rio
  • 85 posts
Posted 11 January 2019 - 01:27 PM
Thanks Graeme :)
#4 Steve220
Steve220
  • 5,067 posts
  • Local Club: BMC
Posted 11 January 2019 - 01:35 PM
Wheres your washer bottle?
#5 Rio
Rio
  • 85 posts
Posted 11 January 2019 - 02:26 PM
In the boot Steve
#6 Steve220
Steve220
  • 5,067 posts
  • Local Club: BMC
Posted 11 January 2019 - 02:41 PM
Ah, OK. What can also happen is that one way valve in the boot can seize. Worth replacing :)
#7 Rio
Rio
  • 85 posts
Posted 11 January 2019 - 02:50 PM
Thanks Steve :)
#8 Bobbins
Bobbins
  • 1,507 posts
Posted 11 January 2019 - 03:12 PM
This one.
Stu.
#9 Rio
Rio
  • 85 posts
Posted 11 January 2019 - 03:13 PM
Cheers Stu
#10 Steve220
Steve220
  • 5,067 posts
  • Local Club: BMC
Posted 11 January 2019 - 04:42 PM
https://rover.ebay.c...tm/272841286219
That's what I bought. Same, but cheaper.
#11 Rio
Rio
  • 85 posts
Posted 11 January 2019 - 06:54 PM
Looked at it today and can see the water running down from the pipe right up in the arch near the skuttle behind the air intake pipe work
Access is bad and just asking if I can get to it from behind the dash and if not, can I get to the A post where the tubing runs
Looks a bastar@d of a job
Any ideas or advice appreciated
#12 Steve220
Steve220
  • 5,067 posts
  • Local Club: BMC
Posted 12 January 2019 - 09:31 AM
If you remove the dash, you will see the tube enter the cabin from the engine bay.
#13 Rio
Rio
  • 85 posts
Posted 12 January 2019 - 09:33 AM
Brilliant that’s great news
#14 GraemeC
GraemeC
  • 7,440 posts
Posted 12 January 2019 - 10:30 AM
I would be trying to find a straight pipe joiner (or sacrificing a t-piece to make one) and then attaching the two pipes together at the bottom of the A pillar to use the old one as a draw rope for the new one.
#15 Rio
Rio
  • 85 posts
Posted 12 January 2019 - 10:34 AM
Good idea ;)
