Hi Lo’S
5 replies to this topic
#1 Fastorq
Fastorq
  • 186 posts
Posted 11 January 2019 - 09:59 PM
Seems to be hi lo branded ones and more budget ones.
Is there much difference
#2 nicklouse
  • 18,685 posts
Posted 11 January 2019 - 10:40 PM
yes lots. from the profile of the connection flange. to the means of making the threads in the alloy.
i would only fit the originals as the do improve the suspension with the standard cones.
have a read
http://www.theminifo...hive/?p=2617559
#3 Icey
Icey
  • 1,552 posts
Posted 12 January 2019 - 01:31 AM
We have the budget ones fitted and I’ve not used a genuine set so can’t comment on how the ride varies. The mount profile does interact with the edge of the cone so if there’s a difference it will be noticeable.
My comment on the budget ones is.....they’re surprisingly good quality. I’ve not had a problem adjusting them after a couple of years on the car and the materials have stood up without obvious corrosion or degradation. The real-rest will be when it comes to changing the knuckles, if they’ve either corroded in place or deformed.
#4 Fastorq
Fastorq
  • 186 posts
Posted 12 January 2019 - 08:42 AM
For what they are , it's difficult to see how budget ones could be any worse than branded ones.
I suppose grade of alloy could be a difference or quality of machining or dimensions maybe?
Which ones have you got .. Did you have to machine them (that's not a problem for me)
I could probably make a set myself if I had a pattern but the budget ones are so inexpensive.
DavidR
#5 Icey
Icey
  • 1,552 posts
Posted 12 January 2019 - 09:07 AM
We’ve got the ‘standard’ units from Somerford - ASU001 and 002.
No machining, they just fitting.
#6 nicklouse
  • 18,685 posts
Posted 12 January 2019 - 12:44 PM
DavidR
rolling thread is more costly than cutting thread.
