Wheels Lock When Changing Gear
9 replies to this topic
#1 [email protected]
[email protected]
    Just On Tickover
  • 5 posts
Posted 16 January 2019 - 05:35 PM
Hi. I'm having a problem when I change gear from 1st to 2nd the wheels lock, engine keeps running ie clutch is disengaged. Dosen't happen between 2nd and 3ed or 3ed to 4th.
Any thoughts?
#2 DeadSquare
DeadSquare
  • 3,214 posts
Posted 16 January 2019 - 05:58 PM
To get this straight.
First gear works OK ?
Second gear works OK ?  ............. (as do 3rd 7 4th)
But wheels lock when changing up from 1st to 2nd
Do the wheels lock when changing down from 2nd to 1st ?
#3 Spider
  • 15,249 posts
Posted 16 January 2019 - 06:13 PM
What type of gearbox do you have (Rod or Remote. If Rod, what's the Case Number?) and what's it's history?
How long has it been doing this for?
#4 [email protected]
[email protected]
    Just On Tickover
  • 5 posts
Posted 16 January 2019 - 06:51 PM
Deadsquare
        All gears work OK. Not tried changing 1st to 2nd.
#5 [email protected]
[email protected]
    Just On Tickover
  • 5 posts
Posted 16 January 2019 - 06:53 PM
Moke spider
       Rod change, don't know the case number at the moment, no history as I bought it as a none runner.
#6 viz139
viz139
  • 694 posts
  • Local Club: Irish Mini Owners Club
Posted 21 January 2019 - 09:29 PM
If the balk ring on first jammed onto the first gear selecting second would lock the gearbox in two gears at once. I assume the lock up only happens for a split second as the force breaks the balk ring from the gear. Try starting off in second and than third and forth. It will probably also change down ok from second to first.
#7 Spider
  • 15,249 posts
Posted 22 January 2019 - 08:40 AM
I have come across something similar once.
It was quite a while back, but thinking it through a bit, I think the 3rd / 4th Gear is assembled back to front.
The other thing it could be is a crack case, on the centre web, above the Main Bearing.
Regardless, the engine will need to come out and the gearbox off.
#8 [email protected]
[email protected]
    Just On Tickover
  • 5 posts
Posted 22 January 2019 - 10:06 AM
Thanks for the advice. I'm taking the engine/gbox out and try and see what's happening.
#9 Rorf
Rorf
  • 866 posts
Posted 22 January 2019 - 12:04 PM
Please let us know what you find when the box is stripped. :proud:
#10 InnoCooperExport
InnoCooperExport
  • 372 posts
  • Local Club: Mini Seven Club Nederland
Posted 22 January 2019 - 09:37 PM
When I rebuilt my rod change box it would seize up when I tried to select gears as well. Turned out the baulk rings were seizing up so it could well be that. Good luck!
