So my oil pump is almost knackered. Pressure is dropping to 10psi at idle when the oil is really hot. So i guess its time to take the engine out.
This will be my first attempt at a rebuild. I have a Haynes manual, a torque wrench and youtube videos to guide me. It's going to be an adventure!
As everything takes 3 weeks to get here from the UK I figured I'd order some of the essentials now even before I've taken out the engine. I'm trying to keep the cost down, but if I'm going to the hassle of taking out the engine to change the oil pump I might as well change the things most likely to wear out as well. What are the essentials that must be changed everytime the engine is opened up? I've already ordered the minispares engine rebuild gasket kit, so I figure I have all seals sorted. So it's on to parts now.
Here's what I have. Please fill in the gaps:
1) Main Bearing
2) Bigend bearing
3) Cam followers
4) Oil Pump
5) Water Pump
6) Unleaded vale seats
7) Valve guides
8) timing chain tensioner
9) central oil pickup
What else needs doing?
also if you could post links to minispares parts or the part numbers that would really help me in finding the right parts to order. This is a road use car, not exactly fast road, but I'd like it to perform better than it currently is (fully stock)
Edited by BaronVonchesto, 20 January 2019 - 05:41 PM.
