Wiring A Smiths Rev Counter To An Mpi
5 replies to this topic
#1 craig 1010cc
craig 1010cc
  • 1,165 posts
Posted 23 January 2019 - 12:34 PM
Having done some searching, I can't find an answer to this.
I'm in the process of doing a full MPI conversion into Pootle (my 85 city E) including the full MPI wiring loom. I am retaining the centre speedo and the smiths dials I have run for the past 16 years. Water temp, oil pressure and the warning lights seem easy enough, but how is rev counter wired in?
The rev counter is a 80mm smiths (same as this
https://www.minispor...ome-black.html
which I bought new 16 years ago and was last running on late electric ignition dizzy set up) with a number of switches at the back. The OEM feed wire (with the bullet connector?) will provide the feed, but what configuration of the switches do I need? I've seen the conversion used in the past, so I assume they weren't there just for looks and it can be set up right
Cheers in advance
Craig
#2 cian
cian
  • 869 posts
  • Local Club: Minis In Northern Ireland
Posted 23 January 2019 - 12:40 PM
Yes that is correct but you need a rev counter that reads 2 cylinders and not 4 as the mpi ignition system is a “ wasted spark “ if you put a rev counter for a four cylinder car it will not work
My experience others may say otherwise
#3 craig 1010cc
craig 1010cc
  • 1,165 posts
Posted 09 March 2019 - 06:59 PM
Done some more digging, and I have a Smiths RCV1004-00CA rev counter, which is semi programmable and has 6 switches.
I've found the instructions for it here
https://www.caigauge.../pil019-367.pdf
previously, for my old carb'd engine with a lucas electronic ignition i had then set
1=off
2=off
3=on
4=off
5=on
6=off
So following the instructions, I went for
1=off
2=off
3=on
4=on
5=on
6=off
I fire up with it all connected today and at tickover it hardly moves (100rmp or so), but does rise with the rev's
Any thoughts
#4 genpop
genpop
  • 508 posts
Posted 10 March 2019 - 08:04 AM
according to the wiring diagramm you have to connect to C159-25 from ecu, then I would try old and new switch settings
  • Attached File  mpi.JPG   31.42K   5 downloads
#5 viz139
viz139
  • 670 posts
  • Local Club: Irish Mini Owners Club
Posted 10 March 2019 - 10:55 PM
What you need is one of these
http://trigger-wheel...en-uk/p129.html
Connect the two coil wires WS and WB to the two inputs of the modual the the output goes to the tacho
#6 craig 1010cc
craig 1010cc
  • 1,165 posts
Posted 05 October 2019 - 03:33 PM
Ended up getting a new Rev counter from rally designs (only £60, much cheaper than a smiths one, but doesn’t look as good sadly) that would run in 2 cylinders configuration
