Auto Not Changing
Posted 28 January 2019 - 08:26 AM
Posted 28 January 2019 - 09:47 AM
It does sound like the shifter cable needs adjusting.
Posted 28 January 2019 - 02:50 PM
This governs the the speeds at which the box shifts gear.
It needs to be adjusted correctly and you do it by locking the bell crank with a suitably sized drill bit. The size I used escapes me but I'm sure I used the guide in the Haynes to do it.
They are also fussy about having the right level of oil.
Has it got 10/40 oil in? The later ap2 had that specified rather than 20/50 but I'm not sure of the cut over dates.
Posted 29 January 2019 - 08:28 AM
Here's the correct way to adjust the Shifter. It is a critical adjustment and incorrect adjustment can quickly lead to damage of the gearbox. It is easy enough, just take your time setting it and then check it after a run.
The method for adjusting these early Autos is different from the latter ones.
Only once you have that right, you can also set the Kick-down Adjustment;-
This next diagram, while clear, is hard to find on the car, but is accessible, it's down the back side of the engine / gearbox, just over the diff;-
