Sequential Indicator Strip
2 replies to this topic
#1 splintercat
splintercat
  • 616 posts
Posted 28 January 2019 - 07:56 PM
decided to tryto fit some of these to the rear of my mini. Bought a flea bay pair and altho stupidly cheap they do work very very well. bought a new indicator can as well to cope with the load that led s take.
when i connect them in parrallell with my front indicator s directly from the indicator can itself they work a dream BUT as soon as i try to hook them up in my boot either to the left hand side or the right NOTHING happens. all the connections are good everywhere...........why should  a length of wire coming from the can in the engine bay to the rear indicators in my boot make the difference? because that is all it is as far as i can work out?
#2 nicklouse
  • 18,657 posts
Posted 28 January 2019 - 09:09 PM
try swapping the wires around.
#3 splintercat
splintercat
  • 616 posts
Posted 12 February 2019 - 07:16 PM
no the wires ae correct and it was the old problem of bad bad earth connection coupled with the replacement of a decent turn signal relay, which was capable of handling the led's. I now have them working great and i've only fitted them on the rear at present and they are quite a cool, altho not to everyones taste.
thanks anyway and it will be at the IMM in Bristol in August.
