Edited by Benito_S6, 03 February 2019 - 11:30 PM.
Posted 03 February 2019 - 11:04 PM
Posted 03 February 2019 - 11:37 PM
Can i ask why? Is it to stop people steeling it?
FWIF when I was at college my mate had a Beetle & me the Mini and we both used to take the rotor arm out of the distributor if we would leave them somewhere sketchy. I doubt anyone today would even know what a rotor arm is let alone have one to replace to steel your car :)
Posted 03 February 2019 - 11:44 PM
Posted 04 February 2019 - 01:09 AM
where are you putting the switch? what you have shown will just turn the rev counter off.
Posted 04 February 2019 - 02:30 AM
The white wire that goes to the coil - put your switch in there in series.
Posted 04 February 2019 - 09:38 AM
Edited by Benito_S6, 04 February 2019 - 08:40 PM.
Posted 04 February 2019 - 08:15 PM
Posted 04 February 2019 - 08:19 PM
No it won’t. If you earth out the -ve terminal on the coil it will stop the points creating a spark as there is an easier path to ground.
This can be done by tapping into the tacho wire as per the diagram.
it would with the original DWG it has been changed to work.
Posted 04 February 2019 - 08:38 PM
Thanks for getting back to me. That was my understanding also, I haven’t changed the diagram but the diagram the one with blue boxes would infact work?No it won’t. If you earth out the -ve terminal on the coil it will stop the points creating a spark as there is an easier path to ground.where are you putting the switch? what you have shown will just turn the rev counter off.
Edited by Benito_S6, 03 March 2019 - 10:20 PM.
Posted 04 February 2019 - 09:04 PM
Thanks for getting back to me. That was my understanding also, so the diagram that I did with the blue boxes would infact work?
your new diagram seem to be right with the switch earthing the coil out.
Posted 13 May 2025 - 07:40 PM
Posted 14 May 2025 - 02:09 PM
I just put a battery master switch in the boot; in the earth line.
Posted 14 May 2025 - 04:06 PM
The coil fires when the earth of the primary winding is broken causing its field to collapse. Providing an alternative earth, via the rev counter wire, will stop it firing until that earth is opened & the distributor regains control.
It's not a lot, but it might do enough to make an opportunist bottle it.
Posted 14 May 2025 - 04:36 PM
I'm going a slightly different route, I'll use a relay operated by secret switch
that will enable the ignition starter (on key or button, tbc) but when not pressed, you'll just sound the horn
something like this should do it https://cpc.farnell....BhoCmK8QAvD_BwE
so you have n/o for the starter ingition circuit (closes when triggered by the switch) and the n/c for the horn circuit (opens when switch used)
and obviously the horn will also continue to work in the normal way via the stalk button as normal
Edited by stuart bowes, 14 May 2025 - 04:45 PM.
Posted 14 May 2025 - 09:42 PM
