Fuel Gauge Reads Empty
Posted 10 February 2019 - 11:10 AM
Posted 10 February 2019 - 11:53 AM
you say you have checked the wires? how looked at them or with a multi meter for continuity and voltage?
Posted 10 February 2019 - 02:35 PM
Does the temp gauge work?
Posted 10 February 2019 - 02:55 PM
Posted 10 February 2019 - 07:53 PM
Posted 11 February 2019 - 02:44 PM
thanks back at my parents this weekend so will try then, is the sender on the side if the tank? (circular gold piece)
Posted 11 February 2019 - 02:45 PM
Also if it is the sender is it easy to replace? I'm guessing I would need to drain the tank?
Posted 11 February 2019 - 02:52 PM
Easy to replace the sender.
The fuel level only needs to be below the level of the sender backplate.
Posted 11 February 2019 - 04:57 PM
Probably best to disconnect the battery.
Remove sender wire(s).
Take a hammer and punch. Knock the locking ring Anti clockwise about a 3rd of a turn.
A twist and wiggle will have the old sender out.
Installing the new one can be a bit of a fiddle.
Replace the gasket!
Keep the float as close to the side of the tank as possible, or it will catch on a baffle. You may have to insert it at completely the wrong angle, then rotate it at the last moment.
Then knock the locking ring round clockwise.
Posted 16 February 2019 - 11:10 AM
Posted 16 February 2019 - 04:03 PM
Posted 16 February 2019 - 07:08 PM
Did you connect the wires on the sender together?
Posted 16 February 2019 - 08:06 PM
Posted 20 February 2019 - 08:53 PM
Posted 20 February 2019 - 09:59 PM
