100Mph Replacement Speedo Help!
Posted 18 February 2019 - 12:36 PM
I have a 1967 mk 2 mini and want to fit a replacement speedo however it is the 100mph type rather than the existing 90mph one. I’ve been told this is possible but it won’t register the correct speed unless I fit some kind of adaptor between the speedo and cable. Any advice would be welcome as I’m not sure what this is and where to buy it from.
Thanks, Nick.
Posted 18 February 2019 - 01:12 PM
you just need to make sure you have the correct drive cogs for the speedo
some reading for you
http://www.guess-wor...Tech/speedo.htm
also keep the 100mph speedo and consider getting it refurbished.
Posted 18 February 2019 - 06:06 PM
Not to sound too boring but i read this article and was pretty amazed at just how interesting it was.......thanks for that, a real treat mate an as I am always changing my centre speedo a bonus, thanks again.
splintercat.
Posted 19 February 2019 - 01:00 PM
Nick, the 100 mph speedo is normally from a 998 Cooper. They are quite rare and the best thing to do is to send yours to Speedy Cables Ltd, in LLanelli who will re-furbish it for a sensible cost and that will keep it original and the drive gears will not be an issue.
Edited by Cooperman, 19 February 2019 - 02:13 PM.
Posted 19 February 2019 - 01:10 PM
i know. hence my last line.
Posted 19 February 2019 - 02:31 PM
Not that any of that makes a difference to the need to swap out the drive gears.
