Timken Bearing Spacer
6 replies to this topic
#1 croc7
croc7
  • 814 posts
Posted 20 February 2019 - 07:52 AM
If the the outer races of the front bearing must seat against the shoulder in the center of the hub, what is the purpose of the spacer as supplied with the Timken tapered bearing set?
#2 nicklouse
  • 18,657 posts
Posted 20 February 2019 - 08:07 AM
to space the inner races.
#3 croc7
croc7
  • 814 posts
Posted 20 February 2019 - 08:40 AM
Hmm. The spacer is not in contact with the inner races- lateral play between them exists. Don’t get it.
#4 nicklouse
  • 18,657 posts
Posted 20 February 2019 - 08:47 AM
should be. opps by inner I mean the smaller of the two.
Attached File  Capture.PNG   55.55K   6 downloads
Edited by nicklouse, 20 February 2019 - 08:52 AM.
#5 nicklouse
  • 18,657 posts
Posted 20 February 2019 - 08:52 AM
some reading
http://www.theminifo...wheel-bearings/
#6 Spider
  • 15,042 posts
Posted 20 February 2019 - 10:44 AM
This came up not too long ago.
Basically it comes down the fact that on the fronts, these are 'back-to-front' to most conventional hub assemblies.
On a 'conventional' hub, the axle is dead and the hub spins around that. That's fine for a lazy (ie, non-driven) wheel.
Where drive is required, the hub is dead and the axle is live. In the Case of the Mini, the live axle is short as it also needs to steer.
Without the spacer, a lock nut on the CV would be required, but as the inner bearings would be free to 'float', when loaded say on cornering. they would bear quite heavily on the shaft of the CV and wear that in short time. By having the spacer in there, it allows the CV nut to be done up very tight, clamping all the inner parts in tight assembly, almost making them as one, so shaft of the CV is loaded over a greater area. It also assists with loading of the bearing too.
Have a good look and think about the pic that Nick posted up ^.
#7 croc7
croc7
  • 814 posts
Posted 20 February 2019 - 07:09 PM
Lots of interesting stuff, makes more sense now.  Thanks.
