Best Battery For Spi With 12" Wheels
14 replies to this topic
#1 brivinci
brivinci
  • 1,192 posts
Posted 21 February 2019 - 09:53 PM
Looks like my battery of 8 years packed it in officially. Of course, on a dark and rainy night...
So, I am interested what size batteries you are running, particularly if you have a factory 12" alloy and, even more particularly, running Yoko A539 12" tires. Currently, my spare is still on my last tire setup, the Yoko A048R, which has a much smaller diameter overall. Sure, I could remove one of my road wheels, stuff it in the boot and measure BUT you guys probably can rattle off the perfect battery in seconds...oh, and its cold out:-)
#2 minimat
minimat
  • 690 posts
  • Local Club: anglian mini club
Posted 22 February 2019 - 12:11 PM
I use an 063, good fit in the box, sensible price and a good power increase, unless you have a massve stereo and loads of spotlights i dont think you need any bigger.My spare wheel is standard 12 in and fits fine.
Edited by minimat, 22 February 2019 - 12:12 PM.
#3 brivinci
brivinci
  • 1,192 posts
Posted 22 February 2019 - 02:12 PM
Well, its an SPi so you have the draw of the EFI system. I also have 4 spots fitted to the front per the factory. Lately when I had everything on, you could see/hear the system stressed. For example, I was driving at night with main beam on, 4 spots on, and heater motor running. I installed a wiper relay thing that lets you have intermittent wipers. I had that set for a every 5 seconds to so. When the wipers would come on, you could hear the heater blower motor change in tune and a slight dimming of the interior lights. Now, the battery was clearly on its way out but it got me thinking.
#4 Mikey205
Mikey205
  • Just Joined
  • 15 posts
  • Local Club: Midlands
Posted 22 February 2019 - 11:21 PM
I’d be looking at having your alternator beefed up a touch to cope with your electrical demands. You ideally need to work out what amps you are pulling with everything switched on (amps = watts / volts). That will give you an idea of whether your alternator is ‘man’ enough for what your expecting of it.
Mike
#5 Wiggy
Wiggy
  • 1,036 posts
Posted 22 February 2019 - 11:36 PM
I used a taller battery (because I had it to hand).
Ended up making new longer battery clamp hooks out of some studding. My Sportspack space saver juuuuust fits beside it.
Out of a MR2 Roadster FYI. I have no idea if it's of a higher capacity.
#6 Wiggy
Wiggy
  • 1,036 posts
Posted 22 February 2019 - 11:39 PM
Just checked. It has 1/3 more capacity.
#7 hunterg30
hunterg30
  • 349 posts
Posted 24 February 2019 - 02:28 PM
Duracell 0273 ,has five years garauntee
#8 brivinci
brivinci
  • 1,192 posts
Posted 25 February 2019 - 05:43 PM
Didnt know Duracell made car batteries. I don't think they sell them here in the USA.
So, what was the stock battery and its output on these SPi cars? I know the alternator fitted from the factory was said to be up to the task. I have not added any major power sucks and can't say that I've noticed this drain happening before. Maybe I should pull the alt and have it tested. It is the original from 1994.
#9 Screwdriver
Screwdriver
  • 281 posts
Posted 16 March 2019 - 08:31 PM
In the same boat, looking for the smallest size (reduces weight) replacement battery that can comfortably handle an air-conditioned SPi. I can hear the change in sound when the heater and headlights are switched on. Lord forbid, I turn the wipers on as well...
#10 Wiggy
Wiggy
  • 1,036 posts
Posted 16 March 2019 - 10:02 PM
I could be wrong, but that sounds like the alternator is struggling to keep up.
#11 brivinci
brivinci
  • 1,192 posts
Posted 20 March 2019 - 10:18 PM
Well, my battery was shot so it needed replacing so it was time. Ended up with a Optima Red Top 34 that fits the battery box and has 800 CCA. Haven’t really drive the car much to see if anything’s changed but now that that is sorted, I can look into the alternator.
#12 brivinci
brivinci
  • 1,192 posts
Posted 20 March 2019 - 11:06 PM
To note: that battery fits very nicely within the box, I’m worried about the spare tire fitment. Currently, my spare is a factory alloy with a Yoko A048R mounted. They are a lower profile then the typical 12” tires out there. It fits, but only just. When I rotate my tires, I’ll see if one of A539s will fit.
#13 Screwdriver
Screwdriver
  • 281 posts
Posted 21 March 2019 - 11:51 PM
Any chance we could see a picture of the Optima installed? I've never heard of a gel pack battery in a Mini but if it fits then it may actually be a smart alternative. What did it cost? Warranty duration?
Edited by Screwdriver, 21 March 2019 - 11:51 PM.
#14 cooperd70
cooperd70
  • 729 posts
Posted 22 March 2019 - 06:08 AM
I have a A539 on a factory 12" alloy in the spare wheel well and use a Tayna E24 Varta Blue Dynamic Car Battery 12V 70Ah. It 'just' fits into the battery box but everything does fit back into the boot with no issues.
However it is a 1990 carb car though and so not sure if it's suitable for a SPi.
#15 brivinci
brivinci
  • 1,192 posts
Posted 23 March 2019 - 02:00 PM
I can’t stand this site. Always have issues posting pix. Hope this works.
Edited by brivinci, 23 March 2019 - 02:15 PM.
