As the title says, the Interior light isn't working I have checked/replaced the fuse and the bulb works as its been tested.
Where does the light ground that isn't attached to the door switches?
Any advise would be appreciated.
Cheers.
Posted 23 February 2019 - 01:39 PM
Cheers.
Posted 23 February 2019 - 01:52 PM
mine only works if i hold the switch against a side. something wrong with the connections. maybe clean yours up first? not sure
Posted 23 February 2019 - 02:07 PM
This type: http://www.minispare...|Back to search
earths through one of the mounting screws. Not sure about the later type.
Posted 23 February 2019 - 02:29 PM
Posted 23 February 2019 - 02:41 PM
Connectors seem fine.
This Type: https://www.minispar...px|Back to shop
And It did the last time i checked, I will recheck
Posted 23 February 2019 - 03:38 PM
Check whether the purple wire is supplying power at the light switch, then move the light switch so that the bulb should light with the doors closed. If that does nothing, does the bulb light when a door is opened. If either/neither of these gets the bulb lit, then it will be one of the purple/white wires connected to the rear-most connectors on the switch. Check those for continuity to the body.
Posted 24 February 2019 - 07:53 AM
@Sussex_pete Thanks for the advise.
