Lower Arm Bushing Replacement Help!
Posted 25 February 2019 - 11:22 PM
I just rebushed the lower arm and fitted it onto the subframe etc before seeing a gap between the pin and frame. On some Facebook research I was told that I need 2 bushes in each arm? I've already got one in there my question is where does the other one go? Is it a matter of both sticking out either side so it fills the gap between the pin and bar?
Any help appreciated before this novice!
Posted 26 February 2019 - 12:09 AM
Yes its 2 bushes one in each side
Posted 26 February 2019 - 07:55 AM
seriously get a Haynes Workshop manual.
and as above two bush per arm one from each side.
image2EZV7UEO.jpg 30.75K
3 downloads
Posted 01 March 2019 - 06:35 AM
Posted 01 March 2019 - 08:47 AM
Who is the best supplier to get these bushes from. Even Minispares items seem to start perishing within 2 years of purchase, and that is not even being used on the road.
Posted 01 March 2019 - 01:40 PM
Maybe rimmers have some originals in stock.
Posted 01 March 2019 - 01:44 PM
Posted 01 March 2019 - 05:54 PM
Yes. There was a change in 1968. The earlier bushes fitted to a different arm, it looked the same (same forging) but the bore for the bush was a different shape. The earlier bushes also didn't have the steel sleeve.
The type in the link is the later bushes.
