Electronic Ignition Module
Posted 12 March 2019 - 10:34 AM
Posted 13 March 2019 - 02:25 PM
Posted 13 March 2019 - 07:56 PM
Posted 14 March 2019 - 09:42 AM
I wonder if you can use the type 65 one? They both use the same coil
As no Minis had 59dm4's as standard only 65's they're correct in claiming it fits all such Minis. I reckon there's a good chance you can make one work if you run out of options.
Posted 14 March 2019 - 10:05 AM
Posted 14 March 2019 - 10:06 AM
picture of the unit you have now? as it may have come from a different car.
Posted 14 March 2019 - 10:46 AM
Rob
Posted 14 March 2019 - 11:31 AM
Posted 14 March 2019 - 11:49 AM
Thanks for the responses. Unfortunately I do not have the original. The engine is from metro turbo. I have a used 65DM4 that I could use with original module. But I also have NOS genuine Austin 59DM4 that was also used on the earlier engines. As the 59DM4 is new I would prefer to use this one. Just seem impossible to locate a new module
Rob
so is the dizzy from the Metro Turbo?
Posted 14 March 2019 - 01:39 PM
Robso is the dizzy from the Metro Turbo?
if it is it used the Lucas AB14 amplifier.
Posted 14 March 2019 - 02:24 PM
Yes it’s originally from metro turbo. Just no module or connectors.
Posted 14 March 2019 - 02:30 PM
so you have the two wire coming out with the terminal on the end? so you need a amplifier as above or an equivalent. were fitted to quite a few BL cars. but most went to the states. seen then used from about 80 quid to new at 500! there is not much to them (google) so surprised the dizzy doc cant make one up.
Posted 14 March 2019 - 06:54 PM
This is a picture of the same 59DM4 that i have but with module and cables included. I think this is what i need
