Roller Rockers
23 replies to this topic
#1 Fastorq
Fastorq
  • 186 posts
Posted 14 March 2019 - 08:22 PM
Best ones ?
MED, Minispares or Minisport?
#2 nicklouse
  • 18,697 posts
Posted 14 March 2019 - 08:26 PM
the MED ones look the closest to the Windsor ones which were the best. i would just make sure that the main bearings are bushed not rollers.
#3 imack
imack
  • 2,205 posts
Posted 14 March 2019 - 08:30 PM
I'm running MED ones, very happy with them. Not used minispares or minisport ones. MED version run on an over sized rocker shaft, 18mm from memory, think the others use standard or thick walled 14mm shafts.
Edited by imack, 14 March 2019 - 08:51 PM.
#4 imack
imack
  • 2,205 posts
Posted 14 March 2019 - 08:33 PM
MED ones don't run on replaceable bushes, they run straight on the shaft. There is an MED tech video on youtube with more details.
I've got the standard version, not the more expensive LDX version.
#5 Bobbins
Bobbins
  • 1,514 posts
Posted 14 March 2019 - 08:49 PM
Any advantages of using the 1.3 ratio rather than 1.5 (other than reduced valve stem wear)?
#6 imack
imack
  • 2,205 posts
Posted 14 March 2019 - 09:05 PM
Over sized ball adjuster screw threads too.
#7 ukcooper
ukcooper
  • 1,625 posts
Posted 14 March 2019 - 10:24 PM
med
#8 imack
imack
  • 2,205 posts
Posted 15 March 2019 - 05:44 AM
[quote name="Bobbins" post="3587695" timestamp="1552596572"]
Any advantages of using the 1.3 ratio rather than 1.5 (other than reduced valve stem wear)?[/quote
I think some engines/cam combinations work better with 1.3 ratio. Also certain race regs demand 1.3 rocker ratios.
#9 Inno
Inno
  • 138 posts
Posted 15 March 2019 - 07:39 AM
...not an expert and only doing some research for my own engine but understood that the camshaft wear is the main threat and disadvantage of 1.5 rockers - much lower longevity for a street used engine.
Guess that is not a problem for a race/track engine that will be checked and rebuilt on a scheduled bases anyhow.
#10 Spider
  • 15,142 posts
Posted 15 March 2019 - 07:51 AM
Best ones ?
MED. They are designed and made better than the other two and that's reflected in the price.
I've broken a set of Mini Sport ones and likewise on the Mini Spares version.
There can be a lot of reasons for increased Cam Wear which is all too easy to blame on the Rockers. If the Cam has received proper treatment and is in fact ground the right way in the first place, run with compatible Followers and run in when fitted, they won't suffer undue wear from running 1.5 Rockers.
#11 GraemeC
GraemeC
  • 7,440 posts
Posted 15 March 2019 - 10:05 AM
I've broken MED ones (none LDX version).
They are bushed.
#12 DeadSquare
DeadSquare
  • 3,189 posts
Posted 15 March 2019 - 10:06 AM
50 years ago, I used to use Triumph Spitfire rockers.
I got a better rocker ratio, and they are offset, which meant that I could offset bore and tube the pushrod holes and then open the inlet ports right out until they broke into the pushrod holes, which I smoothed out with epoxy.
I see that these days they make Triumph Spitfire roller rockers.
#13 Cooperman
  • 23,326 posts
Posted 15 March 2019 - 11:51 AM
The ones I have are superb quality. They were made by Titan Motorsport in St. Neots, Cambs. I think they also make the ones sold by a lot of other retailers.
#14 imack
imack
  • 2,205 posts
Posted 15 March 2019 - 03:01 PM
Found the links
https://www.youtube....Uk4IJ_3nFIIOysQ
#15 Spider
  • 15,142 posts
Posted 15 March 2019 - 05:43 PM
Something different.
Any idea of the ratio ?
I've heard of people also using rockers from one of the Toyota Corolla models too. I think they are 1.43:1 Ratio.
