1. What sort of LSD are you running?
2. What is your Mini used for?
3. How benefical do you find a LSD?
Cheers.
Who runs a LSD??
300bhp/ton
, Oct 17 2006 01:24 PM
7 replies to this topic
Posted 17 October 2006 - 01:24 PM
Posted 17 October 2006 - 01:29 PM
iv been told that a lsd on a road car can be quite tempermental but there are people who run the quaife ATB and have said nothing but good things about them, ill be getting one when the time allows
Posted 17 October 2006 - 02:04 PM
dont know which one i have but it can be a bit of a bu66er when pulling away at junctions and turning at the same time, apart from that its all good.
Posted 17 October 2006 - 02:12 PM
I have ordered my LSD, it is a Quafe and i would NOT settle for anything else.
My mini is not used on the road, it is a tarmac/forrist rally car and so a LSD is perfectly acetable for this situation.
If you have a LSD on the road you will find that you will constantly be steering left to right very slightly to keep it in a straigh line.
i know of people that have died due to crashing because they dont know how to drive with a LSD or use cheap ones that lock up.
If you want one then get a new quafei if you get an old one then take it to somene that knows hat they are doing to check it out before you use it, they are very expensive but on a compation car they are worth it.
Thanks.
Thanks.
Posted 17 October 2006 - 02:18 PM
I agree with the rest, the Quaife is the only one to have for road use. The only downside is that it doesn't work too well with one wheel off the ground.
Posted 17 October 2006 - 03:24 PM
I've got a tranex lsd set up quite tight.
The nature of an lsd, will cause a problem at low speed or pulling away on lock, but for a high powered engine its essential to get the power down.
Posted 18 October 2006 - 01:14 PM
I tried LSD once but I didn't like it
EDIT: Don't take drugs kids!
Edited by mini mad me, 18 October 2006 - 01:14 PM.
Posted 18 October 2006 - 06:21 PM
i've tried the salisbury diff and it was a pig in tarmac jsut general driving but playing on the grass at smd it was great! would have been nie to give it a go on the track!! had a go on the quaife atb diff (in a renaut 5 tubs) just little road driving!! u stil noticed it was there slow speed turning but it didnt make life much harder and by heck it made a difference to not get wheelspin when the boost came on
shame they are so expensive!!
