Hi all,
Trying to get my Spi cooper fired up after a year of resto (engine out etc) but the fuel pump wont prime and I'm not getting a spark. so here is what I have found so far.
Ignition on, disarm immobiliser with fob, red light goes out. (Engine will now turn over)
Remover cover of relay pack located on brake servo. Manually shut fuel relay, fuel pump sounds and fuel gets to injectors.
Checked resistance across crankshaft sensor approx 1400 ohms. When I check resistance ECU plug end (blue and purple wire), still approx 1400.
At coil pack, getting 12v at both +ve and -ve sides. But no HT on crank and no spark.
Any help would be much appreciated.
Spi No Spark, No Fuel Pump Noise.
mini_mezza
, Mar 21 2019 06:34 PM
Best Answer mini_mezza , 22 March 2019 - 09:48 AM
earth strap???
Just checked the eath for ECU. Crap connection, repeated it and she fired on the first turn. Go to the full post
3 replies to this topic
Posted 21 March 2019 - 06:34 PM
Posted 21 March 2019 - 10:39 PM
earth strap???
Posted 22 March 2019 - 09:48 AM Best Answer
earth strap???
Posted 10 August 2019 - 04:24 PM
earth strap???
Just checked the eath for ECU. Crap connection, repeated it and she fired on the first turn.where is the earth for ECU?
Could you tell me where is the earth for ECU?
Edited by rolf, 10 August 2019 - 07:16 PM.
