I already decided to go with single line with 7.4 original front discs….but have dilemma after reading CalverST Technical info and Moke Spider's posts....
The main reason why I wanted single line system was to avoid famous FAM7821 but I understood from articles and posts that split system will work also with only MS72 that can be mounted close to main cylinder for easy access and then to use only one side port from MS72 (blank off the other side port) to lead to the back of the car and than split it for left and right rear brake cylinder.
This means that this same set up can be done with either single line or split system main brake cylinder?
It means:
- locate MS72 at the front bulhead under the hood for easy access,
- blank one side port,
- connect line for back brakes to the other side port (split them left and fright in the back)
- connect MS 72 inlet either from rear port of split system brake cylinder…OR
- connect MS72 inlet from single line cylinder after it was slit for direct connection to front discs??
If this makes sense and rear brakes are in both cases controlled in the same way through MS72, what would be better cylinder to use - single line or split (it does have sort of redundancy with 2 way cylinder) ??
