Led Alternator Warning Light - Resistor
10 replies to this topic
#1 paulrockliffe
paulrockliffe
  • 1,763 posts
Posted 22 March 2019 - 08:12 PM
I no longer have a filament bulb, so I believe the circuit needs a resistor adding so the Alternator will charge the battery.
Does this go in parallel or in series with the led bulb and what resistance should I use, any ideas?
#2 Spider
  • 15,051 posts
Posted 23 March 2019 - 12:18 AM
I use a 68 ohm, 5 watt resistor, but any value up to 220 ohms will work.
You can use a lower watter one, but I prefer to go to this higher wattage type as the surface temperature will be lower.
#3 ACDodd
ACDodd
  • Mini Docs
  • 2,765 posts
Posted 23 March 2019 - 08:23 AM
Indeed 68ohm works perfectly, as does using a bigger wattage as suggested by Moke spider to dissipate the heat better.
Ac
#4 Bobbins
Bobbins
  • 1,502 posts
Posted 23 March 2019 - 11:33 AM
In series or parallel?
#5 Ethel
  • 26,029 posts
Posted 23 March 2019 - 11:40 AM
Parallel
#6 paulrockliffe
paulrockliffe
  • 1,763 posts
Posted 23 March 2019 - 12:47 PM
Nice one, thanks. It'll work in series won't it, with a different resistance?
I did learn this at uni, but can't remember now/missed the lectures.
#7 ACDodd
ACDodd
  • Mini Docs
  • 2,765 posts
Posted 23 March 2019 - 05:35 PM
No it must be connected in parallel with the led.
Ac
#8 paulrockliffe
paulrockliffe
  • 1,763 posts
Posted 23 March 2019 - 09:27 PM
Cool, just waiting for the resistors to arrive now.....
#9 paulrockliffe
paulrockliffe
  • 1,763 posts
Posted 18 April 2019 - 03:59 PM
After being messed about by China, I finally have my resistors!  While I'm plumbing one in, can someone point me in the direction of a quick test to check the alternator is charging?
Ta
#10 Spider
  • 15,051 posts
Posted 18 April 2019 - 06:36 PM
Measure the battery voltage with the engine running at around 1200 RPM of more. should be circa 14.0 - 14.2V.
#11 paulrockliffe
paulrockliffe
  • 1,763 posts
Posted 23 April 2019 - 09:23 AM
Thanks, I fitted the resistor, but I need to get the rest of the dash in before I plug the light in, so I'll test it when I get sorted.....
