Has anyone got a microsquirt running on a mini with the factory manifold?
Im having thoughts of injecting my 998, and using microsquirt. It would either be, spi inlet, mpi inlet, or a home made inlet with a clio spi on it. The question is with mpi, how do you sort the charge robbing the fuel, can that be done with microsquirt, and also with the spi, is that just easier?
The clio inlet idea is i may use a clio ecu, the guy local with the RR is a renault specialist, and i recon he will be able to tune the clio system for me if its viable to fit it. My Bmw rally car with the m44 engine ran factory ecu but with a remapped chip in it that was done on the RR...
Just thinking out loud as although id love to keep the mini all factory, i like the reliability idea of fuel injection and rev limiters etc.
thanks
