Cam Timing Gear Removal
7 replies to this topic
#1 JonnyAlpha
JonnyAlpha
  • 2,748 posts
  • Local Club: Exmoor Minis
Posted 29 March 2019 - 08:59 PM
I am stripping down an MG Metro 1275 engine and have come to take off the timing gears.
The main gear won't pull off and before I start using any force wondered what was the best / safest method to remove it without doing any damage.
#2 nicklouse
  • 18,696 posts
Posted 29 March 2019 - 09:44 PM
Look at it carefully it may just be the key that has moved slightly
#3 DeadSquare
DeadSquare
  • 3,188 posts
Posted 29 March 2019 - 11:40 PM
Is the "Main Gear", as you describe it,  the large cam sprocket ?
#4 Retroman
Retroman
  • 967 posts
  • Local Club: CDMC
Posted 30 March 2019 - 01:08 AM
They can be tight, tightish and then really tight
Pullers will be difficult to set to the right size / length and the chain is to contend with, and nut to damage the crank and cam ends / threads. We ahve a huge snap on set andI nver use them for taking Mini timing gears off.
More often than not 2 big screw drivers on opposite sides of the 1 gear
Prise both levers together you can 'feel' them move
Each wheel will only go so far before you have to do the other as the chain will only walk so far
You usually need to use the cam triangle bolt heads [behind the cam pulley] as lever point as it get further off
Just pulled a really badly built engine down which had both pulleys hammered on [idiot]
The only way was the WMD 3ft pry bar and a smaller one
When they are fitted its worth spending time dressing the pulleys / shafts / keys and keyways
You can sometimes see where the tight spot is
They should both go on and come off by hand, but be a firm fit
#5 DeadSquare
DeadSquare
  • 3,188 posts
Posted 30 March 2019 - 07:43 AM
Position the keyway upwards and remove the cam followers, the dizzy drive and the oil pump.
Slacken the cam nut until it is flush with the end of the cam.
Cover the nut with a piece of hard wood and give it a smart blow with a big hammer to drive the cam through the block.
If it moves, remove the nut and lock washer and carefully positioning  a brass drift, drive the cam further.
#6 unburntfuelinthemorning
  • 1,990 posts
Posted 30 March 2019 - 12:16 PM
WMD 3ft pry bar
Nice.
#7 Retroman
Retroman
  • 967 posts
  • Local Club: CDMC
Posted 30 March 2019 - 12:37 PM
Has to done....
The same muppet had built an engine with 3 bent conrods...one was walking the gudgeon pin about 1mm at TDC / BDC
On the pin centre the piston was out the bore 0.012" one side and 0.002" below the other...!!!
The little ends had been seriously heated to remove the gudgeon pins and then honed out for floating pins on forged 998 pistons
Just one horror story of many in one unit.
#8 JonnyAlpha
JonnyAlpha
  • 2,748 posts
Posted 30 March 2019 - 06:57 PM
Two screwdrivers worked a treat :-)
