Hi everyone
Can anyone advise where I could obtain replacements for the above
Thank you
Spi Coolant Tubes / Pipes
Fizzy G
, Apr 04 2019 09:34 PM
6 replies to this topic
Posted 04 April 2019 - 09:34 PM
Posted 05 April 2019 - 06:23 AM
Welcome, most mini retailers including Minispares supply coolant hoses.
minispares.com/shop/classic/Cooling~heating/Water/Hoses~fixings.aspx?070302
Posted 05 April 2019 - 06:27 AM
Hi, just seen your other post. Apologies if you weren't after hoses. I think there was a post on here a while ago which covered the fabrication of the inlet manifold pipes. I'll try and find it.
Posted 05 April 2019 - 08:06 AM
Thank you
The pipes that I need to replace are the steel ones on the underside of the manifold, they are corroded and will fail eventually
Posted 05 April 2019 - 10:40 AM
Have you got a picture?
Posted 05 April 2019 - 12:57 PM
I don't think you can get them. Some one on here made some from brass and bonded them in .
Posted 05 April 2019 - 01:18 PM
OK thanks for the reply
