Inner Rubber Tie Bar Bush
1 reply to this topic
#1 maccers
maccers
  • 1,880 posts
  • Local Club: LSMOC
Posted 05 April 2019 - 12:49 PM
Was having a poke around under the car last weekend, noticed the rubber inner bush on the tie bar rod is getting squashed quite a bit. I fitted minispares upgraded tie bars with the poly outer, rubber inner bushes some years ago, along with new cones and hi-los, adjustable bottom arms etc, had a guy from here (Dave - Ickle Mini) set it all up.
I assume their job is to compress but maybe they have lost their ability to compress and seem stuck?
Just seen they cost less than £5 for a kit so will probably replace them. Passed MOT few weeks back all ok.
#2 richmondclassicsnorthwales
  • 942 posts
Posted 05 April 2019 - 05:11 PM
You can buy a harder rubber bush as opposed to the standard rubber..
With my suspension repair / service / overhaul kits - I use the Polyurethane and hard rubber combination bushes for the lower tie bars
