Spi Exhaust Questions
Posted 05 April 2019 - 05:43 PM
Couple of questions- firstly is there any difference between an injection rc40 and a carb.. length or shape?
Secondly is lcb with rc40 the best way to go? What bore is a standard rc40 aswell please?
Thanks in advance folks
Posted 05 April 2019 - 07:53 PM
The version normally used with carb models is longer and will connect directly to an LCB manifold for instance.
The version for models with a catalytic convertor is shorter and bolts on behind the convertor.
You probably shouldn't prioritise changing the manifold on an spi unless you have modified other areas of the engine a lot as the standard manifold is a sort of LCB type of design anyway and reasonably efficient.
A cat-back RC40 would be beneficial though to get rid of those horrible silencers.
The RC40 is a nice and sensible 13/4" diameter. Inside diameter if I remember correctly.
Posted 05 April 2019 - 08:17 PM
Thanks buddy! That helps a lot!
Posted 05 April 2019 - 09:15 PM
Posted 06 April 2019 - 08:22 AM
Personally I'd get rid of the cat too... the car should still pass the emissions
Can you show evidence of that being legal. I'm not saying it isn't but Ade-Cooper will need to be 100% certain when it comes to MOT time. I agree though, get rid of it if you can, it'll smell like a proper car again. You'll need to keep the oxygen sensor. I'd say the most restrictive part of the system at the moment though are the silencers.
Posted 06 April 2019 - 09:15 AM
