Primary Gear Oil Slinger
5 replies to this topic
#1 Steve220
Steve220
  • 5,115 posts
  • Local Club: BMC
Posted 05 April 2019 - 06:44 PM
Hi all
On rebuilding the engine today, i installed a new primary gear from minispares.  I noticed when it arrived it was missing the 'lip' however, once after installation i realised this was the oil slinger.  It is present and serviceable on my old one, however i didn't put it on the new primary gear.  Am I going to face any issues? Or is it best to pull the gear off (utter pain in the arse) and fit it along with a new seal? Or if i use a primary gear puller, will the seal be ok to reuse?
#2 imack
imack
  • 2,372 posts
Posted 05 April 2019 - 07:04 PM
My minispares primary gear doesn't have the flinger and its been ok, although my other one with a different tooth count I bought from them about 12 years ago does.
Edited by imack, 05 April 2019 - 07:05 PM.
#3 Steve220
Steve220
  • 5,115 posts
  • Local Club: BMC
Posted 05 April 2019 - 07:11 PM
Does have a slinger or does have a problem?
#4 imack
imack
  • 2,372 posts
Posted 05 April 2019 - 07:36 PM
Sorry, the other primary that does have a slinger is an older non floating bush type. The newer one I'm currently running is a floating bush type without a slinger. No problems with either of them, just changed to get different drop gear ratios.
#5 Spider
  • 15,684 posts
Posted 05 April 2019 - 07:51 PM
The early Primary Gears from the Factory didn't have a slinger, it was introduced during production about 65-66-ish due to issues with Oil getting past the seal.
With the latest Black Primary Gear Oil Seal, you will most likely be OK.
#6 imack
imack
  • 2,372 posts
Posted 05 April 2019 - 08:00 PM
I'm running the standard old style orange seal, not had a problem yet....
