Alternator Charging At Almost 16V
17 replies to this topic
#1 MuppetDonkey
MuppetDonkey
  • 53 posts
Posted 05 April 2019 - 07:19 PM
So I've started looking into why my battery is constantly going flat, tested the alternator (at the battery end) and it was running at 15.8V at idle.
From this I am working on the following assumptions:
1: I need a new regulator for the alternator
2: My lovely new battery is probably fried as I took it out for a GOOD run this week.
3: I'm quite lucky it wasn't a lot worse
I have two questions:
- is it worth trying to source and replace the regulator or is it a new alternator job? If the former does anyone have any pointers? there's some kak on ebay that I don't really trust, but I can't really find anything in the normal places.
- is the battery salvageable? It has only had one run, but it was quite a long one
It's a '99 Cooper with 65A alternator.
#2 smurfomatic
smurfomatic
  • 461 posts
Posted 05 April 2019 - 07:38 PM
Had a similar problem a couple of years back, relatively new alternator (bought because the old one had a broken mounting) cooked the battery. Fortunately the battery was still under a 5 year warranty - so carried it the half mile or so to Halfords, got a replacement, re-fitted the old alternator and got going again!
I would personally suggest a new alternator and certainly would check the battery and expect to replace that too.
#3 Spider
  • 15,154 posts
Posted 05 April 2019 - 07:56 PM
I would also suggest checking all the Earths.
#4 johnR
johnR
  • 2,302 posts
Posted 05 April 2019 - 09:33 PM
There was a company selling alternator re-furb kits on Ebay - Gold Lion auto electrics. A complete kit for £15, bearings, rectifier, brushes etc. great company to deal with and much cheaper than replacing the entire unit.
#5 MuppetDonkey
MuppetDonkey
  • 53 posts
Posted 05 April 2019 - 09:49 PM
Annoyingly this was my suspicion.  just a bit of wishful thinking I guess :)
#6 panky
panky
  • 1,792 posts
Posted 05 April 2019 - 09:52 PM
Just did a quick search, stupid cheap
https://www.ebay.co....3.c100033.m2042
I've just changed the alternator on my Commer camper, might try one of these to re-furb the old knackered on.
#7 MuppetDonkey
MuppetDonkey
  • 53 posts
Posted 05 April 2019 - 09:55 PM
Thanks  - this is what I was originally intending to do today - it's just finished a major resto with a mix of new and used parts, so I thought a few bad earths could be the issue as the battery was charging but would only turn over a couple of times before crapping out.
I was just testing the alternator as a formality, didn't for a minute think it would be the problem.
It's my own fault for taxing it this month!!! :)
#8 monkey
monkey
  • 1,382 posts
  • Local Club: Diss Mini Club
Posted 06 April 2019 - 08:39 AM
I had this problem a few weeks back, voltage was all over the place from 11.6 up to 15.9v, I first noticed when driving at night the lights went SUPER bright lol, anyway for speed I brought this...
https://rover.ebay.c...tm/292773240532
Super quick delivery and it’s working a treat, kept the only one to refurb at my leisure
#9 tiger99
tiger99
  • 8,584 posts
Posted 14 April 2019 - 01:24 AM
I strongly recommend checking the calibration of your voltmeter before jumping to any conclusions about the alternator. There was a case on the forum several years ago where the meter being used was probably well out. It is rather common with the cheap, nasty stuff (and some stuff that pretends to be of good quality, and is priced accordingly) that floods the market nowadays.
I have found that a brand new Duracell (not applicable to any other brand) AA battery measures 1.65V at 20 deg C. A stack of 10 in series (stick them in a suitable tube) should measure 16.5V if your meter is ok.
#10 Aroutin
Aroutin
  • 10 posts
Posted 14 April 2019 - 07:32 PM
Control your plus cable connections for oxidation.
What wil also cause an higher charging voltage.
#11 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 17 April 2019 - 09:35 PM
Just to add a point the excess voltage would start to boil off the electrolite and when this get lower than the plates then thats where the damage is done not directly by voltage alone, so sort out the alternator. if your batteries one of the newer sealed type your snookered, if you have access to the cells then have a look at the level. Some sealed batteries have a press in cover you can remove for a look
#12 MuppetDonkey
MuppetDonkey
  • 53 posts
Posted 21 April 2019 - 06:24 PM
So after checking everything I can think of, I found a few questionable connections but my main fault seems to have been quite a rare one ......
..... a faulty multimeter!!
Out of curiosity I tested the other cars, apparently either both had the exact same fault or my multimeter was over reading.  Borrowed my Dad's and you could see the difference.  So I've bought a maintenance charger (which I should have bought anyway) and am letting it charge slowly, that seems to have sorted it - it's able to start multiple times at least.  When its had a few days on charge, I'm going to leave it off charge for a couple of days then see if it starts, just to be sure.
#13 phillrulz
phillrulz
  • 617 posts
Posted 22 April 2019 - 05:43 PM
Thats why in industry a multimeter isnt a legally or health and safety approved instrument to check for dead. We have to use a set voltage indicators.
#14 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 04 May 2019 - 01:41 PM
One of the reasons why I did this post here "Recommend me a multimeter"    http://www.theminifo...e-a-multimeter/
#15 monkey
monkey
  • 1,382 posts
Posted 04 May 2019 - 01:55 PM
Sorry to hijack but...
Do you still recommend the same one? The leads on my cheap multimeter need replacing and I don’t know wether to buy new leads or replace the whole tester
