Heater Take Off
3 replies to this topic
#1 gills85
gills85
  • 80 posts
Posted 06 April 2019 - 10:13 AM
Hi.
I'm putting a 1275 engine together and noticed that the aperture where the heater take off valve should be is sealed.
Can I, or should I, drill through and open it to reconnect it.
Or, should it be fitted elsewhere?
TIA.
#2 unburntfuelinthemorning
  • 2,002 posts
Posted 06 April 2019 - 10:19 AM
Yes you can; you don't have to; many A series engines had a sandwich plate like this http://www.minispare...c/PEG10002.aspx used as a heater outlet between the thermostat housing and head.
Edited by unburntfuelinthemorning, 06 April 2019 - 10:21 AM.
#3 nicklouse
  • 18,998 posts
Posted 06 April 2019 - 10:24 AM
Open it up it is a good way to reduce the temps on cylinder 4
#4 cal844
cal844
  • 9,713 posts
  • Local Club: TFMOC
Posted 06 April 2019 - 10:19 PM
I used both systems above but had to drill through for the heater take off (DSN retrosport) to be fitted. My head had the holes there for the studs
