Shock Absorber Dampers
Posted 11 April 2019 - 06:26 PM
Posted 11 April 2019 - 06:29 PM
A photo of how far you have got, would be helpful.
Posted 11 April 2019 - 07:11 PM
Standard Mini dampers can be a bit like that, especially when worn. They're not that great really. Probably good enough to pass MOT though.
Have you got a workshop manual to work from? You'll avoid most mistakes if you use one.
Posted 11 April 2019 - 09:42 PM
Posted 12 April 2019 - 04:55 AM
Posted 12 April 2019 - 06:44 AM
Springs absorb shocks.
Dampers dampen spring oscillations.
Posted 12 April 2019 - 12:46 PM
Posted 12 April 2019 - 01:44 PM
I'd be asking what they mean by 'worn suspension bushes'. Top arm? Bottom Arm?
Hang around. You'll work it out in time, and don't be afraid to ask if you are in doubt.
Posted 12 April 2019 - 01:56 PM
Posted 12 April 2019 - 01:58 PM
Posted 12 April 2019 - 02:29 PM
Huh? I was referring to the original post that said the car failed on suspension bushes. Surely you would need more information than that from the garage to be able to fix it?
I do apologise: I misread the meaning of your post.
The top arm, having needle rollers, seldom gives trouble, so it probably just means just the rubbers in the lower arm and on front of the tie bar ?.
