Valve Guides - Cast Iron?
9 replies to this topic
#1 Haynes
Haynes
  • 489 posts
Posted 18 April 2019 - 09:16 AM
For as standard 998 head rebuild is there any reason not to use cast iron guides?
Someone mentioned getting some Mag bronze guides, as these seem to be used on all the performance heads.   But minispares are out of stock so will probably go for standard iron ones.
#2 panky
panky
  • 1,792 posts
Posted 18 April 2019 - 10:03 AM
No problem what so ever, get the MPI valve seals while you're at it, better quality.
Edited by panky, 18 April 2019 - 10:05 AM.
#3 Spider
  • 15,136 posts
Posted 18 April 2019 - 11:09 AM
Cast Iron Guides are very good.
The Mag/Bronze ones are also good, but MUCH less forgiving than the CI types.
#4 DeadSquare
DeadSquare
  • 3,188 posts
Posted 18 April 2019 - 11:36 AM
I like plenty of oil down the valve guides.
I call it "Upper Cylinder Lubricant"
It is especially beneficial if you are running on Castrol 'R'.
#5 unburntfuelinthemorning
  • 1,990 posts
Posted 18 April 2019 - 12:46 PM
In what way are they less forgiving?
#6 Cooperman
  • 23,326 posts
Posted 18 April 2019 - 06:44 PM
If the running clearance is too small the valves can seize in the guides.
I always use CI guides with MPI stem seals.
#7 Spider
  • 15,136 posts
If the head over-heats, they usually grab the valves and then float in the head.
#8 unburntfuelinthemorning
  • 1,990 posts
Posted 18 April 2019 - 09:12 PM
Ooo, that's not good.  I have a Calver head with manganese/bronze guides.  Better be extra careful not to overheat it!
#9 Cooperman
  • 23,326 posts
Posted 18 April 2019 - 09:43 PM
I fitted the then-new manganese-bronze guides in a 970 Cooper 'S' which had a 286 cam. The valves seemed to run smoothly in the guides when it was assembled, but when it got hot one valve stuck in its guide. I had to take the head off, open out the guide a bit, but then it happened to another valve, so it was not just a 'happenstance' the first time. I stripped the guides out, fitted cast iron ones, reamed them out accurately and it never gave any more problems.
#10 unburntfuelinthemorning
  • 1,990 posts
Posted 18 April 2019 - 09:49 PM
Fair enough.  The maganese/bronze ones can't be all bad though or they just wouldn't be used.
