Not Starting (77' Mini 998Cc)
4 replies to this topic
#1 SuperDeLuxeNick
SuperDeLuxeNick
  • 615 posts
  • Local Club: West Country Minis
Posted 20 April 2019 - 03:34 PM
Just nipped home to pick up mini on my lunch break and it started up, pulled it out garage, turned off. locked the house etc and now it wont start!
Loud click from the solenoid is there, and battery earth strap feels warm.
On the 5/6th try, i noticed my voltmeter is showing under 12v -will this cause the starter to not turn??
I only had 15 mins to try before having to return to work!
First time the min has let me down!
tried rocking the car in gear.
Plan is to get home and jump or bump start and see if the alternator is charging the battery etc.
Any other pointers to help me get it fixed so i can use int this great weekend weather!
#2 richmondclassicsnorthwales
  • 942 posts
Posted 20 April 2019 - 03:41 PM
well - you need 3 fundamental items for an engine to run - fuel - air and a spark - provided it is turning over
You said it is clicking, is the engine turning ?, if so look at any of the 3 above
If it's clicking only - Starter motor ?
#3 SuperDeLuxeNick
SuperDeLuxeNick
  • 615 posts
Posted 20 April 2019 - 03:43 PM
Sorry - no engine isnt turning, turn the key and there is just a solid click, like a very loud relay which i beleive is the solenoid? Am i correct in thinking that 11.8v is not enough juice?
#4 hhhh
hhhh
  • 422 posts
Posted 20 April 2019 - 03:46 PM
Your battery is weak, but it could just be the starter is jammed. Try turning the square protruding end on the starter motor before trying again.
#5 SuperDeLuxeNick
SuperDeLuxeNick
  • 615 posts
Posted 23 April 2019 - 12:59 PM
Sorted it, must have been a poor earth or connection on the solenoid somewhere.
Took everyting off, electrical cleaner on all contacts etc and it fired up
Thank you
