Ignition Points Question
9 replies to this topic
#1 croc7
croc7
  • 878 posts
Posted 23 April 2019 - 07:14 AM
I recently bought a brand new Lucas 59D4 distributor and it looks like it has a 45D4 baseplate with blue plastic ignition points. Does that make any sense? Thought that the blue points only came with that weird looking fork thing.
Edited by croc7, 23 April 2019 - 07:20 AM.
#2 richmondclassicsnorthwales
  • 942 posts
Posted 23 April 2019 - 07:33 AM
The "blue points" have a little fork as you state. These should sit on the baseplate and the fork sits in between a raised pin (lower left)
This is the activation from the vacuum advance unit.
#3 unburntfuelinthemorning
  • 2,002 posts
Posted 23 April 2019 - 08:25 AM
You normally expect the points with the blue heel to have the fork but there is probably nothing to stop points being made without a fork that are blue in colour.
Is there no pin for the fork (if there was one) to engage with on the baseplate then?
Where did you purchase the unit from?
#4 croc7
croc7
  • 878 posts
Posted 23 April 2019 - 06:09 PM
I purchased the distributor from an offer on ebay.  I'm reasonably sure its a  NOS original Lucas product, a 59D4 but without the vacuum advance unit and no pin on either the upper or lower side of the baseplate for the advance mechanism.  I've been told that the 'blue' points were more robust, having a fair amount of tungsten on the points and a stronger spring.  If true, I'd like to find a spare set.  The 'blue' points that came with the distr are identical to the standard 45D points (red).
Edited by croc7, 23 April 2019 - 06:10 PM.
#5 richmondclassicsnorthwales
  • 942 posts
Posted 23 April 2019 - 08:47 PM
Send me the item sale number so I can look at what you have bought - this is the long number
Let me see what he has sold you, I can see from my side
#6 Ethel
  • 26,580 posts
Posted 23 April 2019 - 09:20 PM
All Lucas points fit essentially the same. It used to be the thing to doctor the wires so you could fit Cooper S points (25D) to a 45D dizzy. The plaggy fork on the 59's points alters the position of the contact pads relative to each other - the hole in it is eccentric to alter the length of the arm. The idea is to spread the spark erosion and keep them in tune longer. That and the oiler felt pad were intended to help stretch the A+ service interval to 12,000 miles. The pin might have been removed for an electronic conversion as it got in the way of some that were designed for 45D's.
#7 Ivor Badger
Ivor Badger
  • 846 posts
Posted 23 April 2019 - 11:12 PM
Beware Intermotor points in a59d distributer. They don't have the slider and  the engine will not  run correct unless you fit the Lucas points with the slider.
#8 croc7
croc7
  • 878 posts
Posted 24 April 2019 - 02:07 AM
Send me the item sale number so I can look up at what you have bought - this is the long number
The long item number from eBay is 254062439340. Hopefully that helps. Another question is what is the power source? The only wire to/from the distributor is a black one that runs from the condenser to the coil. I’m used to using electronic ignition similar to Pertronix system that has red (+) and black (-) wires to the coil.
Edited by croc7, 24 April 2019 - 02:15 AM.
#9 richmondclassicsnorthwales
  • 942 posts
Posted 24 April 2019 - 07:48 AM
There is no fork on the points. These are set GCS124
These are a late set of points. I am not sure if the Lucas 41766 distributor is correct.
Got to be someone with a bit more knowledge on these. I can't find this Lucas number corresponding with Mini
I have never used these points, I don't even stock them.. think they are for Land Rovers
Edited by richmondclassicsnorthwales, 24 April 2019 - 07:56 AM.
#10 croc7
croc7
  • 878 posts
Posted 24 April 2019 - 06:04 PM
The data sheet that I found shows this distr to be used on 1981> Australian mokes.  Thanks for the reply.
