Brake Pedal
4 replies to this topic
#1 splintercat
splintercat
  • 616 posts
Posted 23 April 2019 - 04:21 PM
Am changing my brake servo set up for a yellow tag, dual line non-servo set up as I need the space. I know I have to change the brake pedal set up for a non servo brake pedal as I have been told that the linkage is different..........1 can I not just adapt the linkage without too much hastle instead?
                        2 where do I get a pre-servo wider brake pedal from?   tried everywhere but no joy
                        3 can I change the linkage over by just getting a pedal or do i have to buy the brake box as well?
                         4 are there any thread son here tat covers this as I can't seem to find any.....
help appreciated.........splintercat
#2 cal844
cal844
  • 9,713 posts
  • Local Club: TFMOC
Posted 23 April 2019 - 05:39 PM
You might get away with just removing the extension linkage rod and directly fit the master cylinder to the pedal. You then need to check that the master cylinder will get full range with the pedal resting on the floor.
#3 Broomer
Broomer
  • 1,771 posts
Posted 23 April 2019 - 08:45 PM
I do not think this is true, I seem to remember the servo cars had a larger pin to the master cylinder?
A friend machined a bush and welded it into a servo pedal to overcome this issue, I simply robbed a pedal from a non servo car.
#4 splintercat
splintercat
  • 616 posts
Posted 24 April 2019 - 04:35 PM
if it's just a  case of making a sleeve then i am good with that however trying to source a non servo pedal seems to be giving me a nightmare as I hace been googling this til my fingers ache..........matbe I should try here......
seem to remember you from somewher do you run a k-series?
really do struggle on this site as it wont allow me to access some areass uch as for sale, anwer any posts , thats why i have to use the quote facility when replying to posts...so cant even ask for a brake pedal on this forum ..dammmmmnn
Edited by splintercat, 24 April 2019 - 06:08 PM.
#5 GraemeC
GraemeC
  • 7,467 posts
Posted 24 April 2019 - 06:12 PM
Your Wanted post shows up fine - I’m sure someone will be able to help.
Edited by GraemeC, 24 April 2019 - 06:12 PM.
